***WARNING Cheap chinese calipers WARNING***
Posted: Sun Mar 24, 2013 6:58 pm
Ok it's funny how things happen, and we have had a few conflabs about cheap nasty chinese copy calpiers for the Mx/Roadsters that are doing the rounds, more so on the Bay of E, but are also being sold through auto outlets.
If they are cheap, then they are cheap for a reason, unlucky for a fellow member that as been sold and fitted one of these copies, but lucky for you lot for me to be able to post this info up.
This had been fitted for just 2 weeks and he was having problems from the off from fitting it on the handbrake side unknowing what he had bought,and no matter how much he followed our guides could not get it to work correct?
So while his pride and joy was with Ste at the body shop, i nipped around one evening to set it up for him, while under her i could see that it was a copy, and could not do anything untill Ste had finished, so she could come to me to sort.
So i have taken some pic's to show the differences to look out for, please please please do not buy these units, they are not good, and for something that you need to put trust in to save your life one day, well the choice is yours.
Copy caliper ,note the lack of pressed in info on the body...
OE caliper........
Copy caliper handbrake arm pulling out and pin for the spring.....
OE calpier arm and pin, (note even the arm is different)
Copy caliper, which you can see the gap on the hanbrake arm pin..
OE caliper......
Hope these pic's make others see sense not to buy, as this is just one issue that i have seen with them fronts and rears.
OE caliper........
OE caliper......
