Mk1/Mk2 Interior lights mod!
The JDM junkie
Postby The JDM junkie » Mon May 13, 2013 9:37 pm
Before we start if you are following this to do the same to your car these are the lights we used; they are found for a cheap price on ebay. There called vauxhaull boot/interior lights, they are found on almost every model of vauxhaull. Common models include: Astra, Corsa and Insignia. Below is a picture of the lights as a reference for searching.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00284.jpg.html]Image[/url][/url]
First things first, locate the following piece of trim inside the cab. (Ignoring the wires)
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00280.jpg.html]Image[/url][/url]
Remove the trim, this is easily done with your fingers.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00281.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00283.jpg.html]Image[/url][/url]
Once both pieces of trim have been removed, make yourself a cardboard cut out of the trim with a hole cut in the middle big enough for the light to fit though.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00286.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00287.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00288.jpg.html]Image[/url][/url]
This next bit requires extreme concentration (so Mm did it). Put the template for the light over the top of the trim. Now, with a sharp object engrave a line into the trim (following the outer line of the template as demonstrated in the pictures below).
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00289.jpg.html]Image[/url][/url]
The red line indicates where about's your engraved line should be. (Please keep in mind that the red line will not be 100% accurate as it was drew in 2 seconds for the soul purpose of this how to)
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/a25275cf-6aec-47d5-9af5-420805561c1b.jpg.html]Image[/url][/url]
Tah-Dah!
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00291.jpg.html]Image[/url][/url]
Again extreme concentration take care. Using the trusty dremel cut as accurately as possible on your engraved line.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00302.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00292.jpg.html]Image[/url][/url]
Remove the cut out piece.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00294.jpg.html]Image[/url][/url]
The lights may not slide in first time, so using your self judgement cut some more off the trim until it fits. You do not want the lights to be too loose but at the same time you do not want it to hard to squeeze into or the trim will break.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00295.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00296.jpg.html]Image[/url][/url]
The way you must slide them back in.
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00298.jpg.html]Image[/url][/url]
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00300.jpg.html]Image[/url][/url]
And there in!!!
[url][URL=http://s1156.photobucket.com/user/Mini-MM/media/DSC00301.jpg.html]Image[/url][/url]
All you have to do now is wire them in. On a mk1 (you lucky lot) the wiring is already there so it's more or less plug and play. But, on a mk2 you'll have to wire from scratch and before you ask, my dad is working on posting up a wiring diagram for you mk2 and for the later Mk 1 owners/ moders out there!
Your not just a Mazda Mender, your a Mazda Moder!
-Mini MM
Last edited by The JDM junkie on Fri May 24, 2013 8:50 pm, edited 1 time in total.
1993 1.6 mk1.5 In Silverstone metallic. -Being made special :)
I am one of the Buccaneer5!
binarypunk
Re: Mk1/Mk2 Interior lights mod!
Postby binarypunk » Mon May 13, 2013 10:19 pm
Good guide! Can I ask a big favour??
If you get a minute can you unscrew a door switch and ground it through an ammeter to see what the total current is with all those lights?
Would be useful to know for the courtesy light mod to make sure it can cope with the load.
(also you might want to go up to a 15A room fuse to avoid potential blowage)
Postby Mazda Mender » Mon May 13, 2013 10:39 pm
Those lights are a replacement for the MK 1 standard ones as Daryl's MK 1 has a MK 2 dash so lost the MK 1 interior lights, so will be using the same amps, the later Mk 1 and Mk 2's have a bonded on reversing mirror on the screen, where as the early cars are screwed to the top of the inner windscreen frame/trim, the later Mx/roadsters have the interior light where the early mirror was fitted, so the mod is for lower lights/foot well lights if you like.
With Daryl's having a converted dash swap he has no interior light, my Mk 2's have them fitted with LEDs bulbs and footwell light which are also LED's.
binarypunk
Postby binarypunk » Mon May 13, 2013 10:41 pm
Oh I thought they were additional to the existing lights...in that case not to worry. :-)
Hamish
Postby Hamish » Mon May 13, 2013 10:48 pm
Nice and tidy... like it a lot :)
Regards, Hammy.
Postby Mazda Mender » Mon May 13, 2013 10:48 pm
Some do add them (or did) as extra lights on the Mk 1's with the dash interior lights also Jon, you could get them as an aftermarket kit many moons ago, but have not seen them for years? unless Mx5parts sell them for re-mortgage money?
snowman
Postby snowman » Tue May 14, 2013 4:03 am
Nice write up :text-thankyouyellow:
Something else for me to do... :-D
2006 MK3
Galaxy Grey
1.8
Return to “Electrics”
