*****Written by flea *******
Feed a length of wire (make sure it has no sharp areas) down from the top tray (located over the driver right shoulder behind the seat) to where the tube has come detached (if your working alone bend the top of the wire so it does not fall below the tray) Feed the detached tube over the wire from under the car (take care not to damage the small flap at the bottom of the tube) Bend the wire so it holds the tube at the bottom. From the top slowly pull the wire until the top of the tube is adjacent to the connecting point below the tray. You may need to locate the tube to the right place. Then pulling the wire again until it is in position.
Drain Tube (replacing)
2nd Weston Park April 2017
