Mk 2.5 aftermarket headlight angel eye led fix
Postby Mazda Mender » Sat Aug 09, 2014 11:25 pm
As nice as these are, owners are hitting a problem with the Angel eye LEDS failing or not even working straight from the box as i myself hit, so in mazda mender fashion i went on a mission to solve it and share my fix, this is a simple but permeant fix to the problem for good for the cost of ÂŁ10 and a bit of time/upgrading.
So have you bought these in clear black version or clear chrome version...
This is the little LED that is giving the head ache that come with the light units which is hit and miss if they work or not, and the biggest problem is that you cannot get new ones :sad:
So after great expense and god knows how many different bulbs in different voltages i found these as a replacement...
So this is the How to on the conversion for good and the LED bulbs are easy to get if one does fail :handgestures-thumbup:
Remove the unit from the Roadster and turn upside down...
This is the voltage step down box that needs to be cut out and removed for good that works for the angel eyes LED's not the DRL LED's....
You need to pop the rubber grommets and pull the old LED bulbs from the units...
Next is cut the step down box off and re solder the joins or crimp....
Heat shrink for over the soldered joins...
Hope this helps :handgestures-thumbup: :wink:
Link to follow on where to get the 12volt LEDs from..
http://www.body-kit.co.uk/product.php/1 ... cebf1ff804
http://www.body-kit.co.uk/ ,Owner is Jeff Soane very helpful chap :handgestures-thumbup:
Return to “Lights and Electrics”
