Members and searchers please be aware that some of our 'how to' guides do not currently show the intended help photos. This is because photobucket wants to charge a monthly amount for us to view our own pics. The photos are currently being replaced. If you need one of our guides and it is missing pics please let one of the Admin team know and we will make that one a priority for you.
MK 1,2,2.5 Single central windscreen wiper...
Postby Mazda Mender » Wed Jan 28, 2015 8:14 am
This is a how to for those that want something different. A single central windscreen wiper that echo's of the 70's, there are a few bits you will need but nothing that will kill your pocket for this look and use like other kits that were out there that are no longer available .
**** please note that the how to below is for the MK 1 only as the MK 2/2.5 kits need a little more parts and more time to fit, how to for the 2's will follow very soon******
The kit will contain...
1 x 22" wiper blade,
1 x rubber grommet,
1 x rotation arm for the wiper motor.
Tools required...
12mm ring spanner,
10mm ring spanner,
Ratchet with small extension and 12mm socket.
large flat bladed screw driver or trim tool,
and a dry hour.
Raise the the bonnet and lock it onto it's stay/prop...
Remove the drivers side wiper arm by removing the rubber grommet that cover the 12mm nut with the ratchet...
Pop the knuckles with the screw driver or trim tool.....
At the motor arm...
And the middle junction....
Unbolt the the wiper motor arm with the 12mm ring spanner and keep safe, we will need to reuse the lock washer and nut, and the old arm needs to be put away safe as that will be needed to be sent back for your return deposit....
Bolt the new wiper arm in place reusing the lock washer and nut....
Pop the knuckle back on....
Remove the old 18" wiper blade and fit the new 22"....
Now it can be a bit tight as different makes we have tested will either miss or hit the windscreen trim...
So we recommend just nipping a little bit off with some sharp scissors...
Now you need to finish removing the Drivers side arm and mechanism, ( put this away safe in case you ever want to return her back to standard) this can be done without removing the windscreen scuttle trim with the 10mm ring spanner, please take care as the scuttle trim can be fragile, once removed just fit the rubber blanking grommet supplied...
Now it is just a case of adjusting the wiper motor arm and the wiper blade arm for where you personally want it to park.
******Vid to be added****
Kits can be bought and delivered through Doctor Mx-5 keeping the 5 alive in Southampton
http://www.doctormx5.co/
Tele :- 01489 896907
Review..... very easy and simple kit to install in no time ,plus the fact that it is very easy to return to OE twin with using OE parts, bit of fiddling to sort out parking but no big hassle, would of liked a bigger sweep if poss, but looks the part, the old motor arm will need to be returned for a deposit taken so for cost and sweep.... 7 out of 10
Mk 1 Eunos 93 black V.S II 1.8 fettled,
Mk 1 Eunos 96 1.8 blue B2...being fettled
Mk1 Eunos 93 1.6 black S special being fettled
shapps
Re: MK 1,2,2.5 Single central windscreen wiper...
Postby shapps » Sun Feb 07, 2016 2:45 pm
Not bad. Agreed the sweep could be better and the faff of getting the position right broke the supplied wiper blade but eventually got it right. Image
Shapps
1996 Eunos Roadster VR-Limited - A
15x7 Rays Engineering Mazdaspeed MS-01Rs
Gaz Classics dropped by 35mm
Cobalt Cat-back Exhaust
Maxogen Intake
OST Rad cooling panel
Refurb'd Interior
Build Thread
Shadgrind
Postby Shadgrind » Thu Feb 18, 2016 11:37 am
Really looking forward to the Mk2 version!
Mk2 Twilight Blue. 1.8
GV Front Lip, Rear Wing. Blue LED instrument Lights. Direnza coil overs lowered quite a bit.
JDM handbrake and gear lever. K&N air filter, STD airbox.
Reversing sensors, rear view mirror display. De Tangoed lights, fitted silvered bulbs in indicators. LED sidelights. Heated seat pads fitted into seats two stage heating.
Gas strut from Corsa and remote boot solenoid!
Mk1 OPG & sender, modded temp gauge so it works (they don't normally)!
Rear spoiler, BMW clock. Mk2.5 centre console and clocks. Nardi leather steering wheel.
Low fuel Autolink light.
Ram air pipe fitted, taking air from scuttle.
Style bar.
Postby Mazda Mender » Fri Feb 26, 2016 7:53 am
I'll get in touch over it ;0)
Shadgrind
Postby Shadgrind » Sat Apr 30, 2016 8:52 am
I don't think it is that easy with the Mk2 as the pass wiper spindle is not centralised? If it was the quite easy to do just extending the sweep.
Style bar.
Postby Mazda Mender » Mon May 02, 2016 11:50 pm
It's not in the centre with the Mk1's .
Return to “Doctor Mx5”
