Hi All,
how do I go about tightening the fan belt, with the cooler weather it now squeals for a bit when I start up.
Many thanks
Steve
Fan belt
Re: Fan belt
Loosen the top & bottom bolts on the alternator & then adjust the tension bolt at the side. Then tighten both bolts back up.
Re: Fan belt
Don't forget to also loosen the adjuster block prior to tensioning the belt, otherwise you'll bend the adjuster bolt.
Re: Fan belt
Tangoman wrote:Don't forget to also loosen the adjuster block prior to tensioning the belt, otherwise you'll bend the adjuster bolt.
Re: Fan belt
tnx both :)
Re: Fan belt
Whilst you are there you might want to pop a spot of copper slip on the adjuster bolt to keep it free for next time!
Ricolas
Beckenham, Kent
Beckenham, Kent
- BenF
- Epic Poster
Re: Fan belt
We're assuming you know how to check tension?
BRG MKI '90 F-SPEC
'ad victorem ire spolia'
my build (condensed)
Sponsor - PROTECH SHOCKS
Supplier - AUTOLINK
Supplier - AUTOLINK
- binarypunk
Re: Fan belt
Indeed...a squeaky belt is either a sign of poor tension, or a worn out belt. If the tension is correct but it still squeals, you need a new belt.
At the centre of the longest run of the belt, you should just be able to turn it 90deg using your finger and thumb. Don't overtighten to compensate for a worn belt as you'll kill your alternator bearings.
- BenF
- Epic Poster
Re: Fan belt
And if it's a multi-vee, then just over 45 degrees on the twist
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
Re: Fan belt
tnx all - job done - sucessfully I think, slackened off bolt holding the alt in place then turned the adjuster bolt until the belt was similar to the other belt.
then did the holding bolt up again :)
saved me a trip to garage - thank all.
Re: Fan belt
Well done. No job to small & cash still in your pocket
