Coolant rerouting
- BenF
- Epic Poster
Coolant rerouting
Lots of this on the web, anyone in here do theirs?
BRG MKI '90 F-SPEC
'ad victorem ire spolia'
my build (condensed)
Sponsor - PROTECH SHOCKS
Supplier - AUTOLINK
Supplier - AUTOLINK
- BenF
- Epic Poster
Re: Coolant rerouting
Ummmmmm.... please tell me you're aware of the coolant stalling problem around cylinder 4???
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
never heard of it, please share this problem from the internet goss?
- BenF
- Epic Poster
I'll post up the info I have, but essentially, when the B6 & BP engines were lifted from the 323 (in which they're transverse mounted) the coolant flow had to be reversed for the packaging reasons associated with longitudinal mounting. Ever wondered why the hot outlet and thermostat are directly above the thermostat? not good for flow and I would agree with 'internet theory' on this. As you'll see below on the flow diagram, no.4 is being cooled (in effect) by the heater matrix:
Looking at this in physics terms, the heater plumbing is say 1/2" bore (13mm) versus the main cooling system at around 1" bore (26mm). The engine being designed for the 323, and optimised for the flow path from front (no.1) lower to rear (no.4) upper the coolant pressure will build up in the area of no.4 effectively 'damming' and reversing the flow because it can't exit quick enough in that direction.
There are also many reports of hot-running enrichment - a safety mode in the ECU to prevent the engine running lean and melting - being triggered because of the overheating (you've heard '5's run hot?) leading to reduced efficiency and burning dirty.
Apparently Mazda themselves modified the headgasket around no.1 in '99 to limit the flow in that area and increase pressure around the other cylinders to keep coolant moving.
So the reroute is as shown here:
Now, I'm not a thermo-dynamicist but this (to me at least) makes much more sense as it returns the system to how it was meant to work in the first place?
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
Maybe it might make a difference to a track car running at full top end for a longer period??? but what would this do or mean to a basic road car? plus the fact that the Mk 1 engine is far better than the rest,Times out on VVT Engine, but the 1.8cc versions right through prouduction as always been the weaker of the two, the Mk 1 was over engineered from day one, i have never had anyone have a issue or hit any ploblems with the OE set up.
The engine does run hot ,thats why the heaters are so great folks, and i understand about the need for cooling them as most will fit a after market high flow alloy rad ,and or better fans ,as over heater is a killer on these ,more so than the Mk 2 1.8 useing oil and running out because owners are trusting a false gauge than checking the oil level every week.
I understand the cooling side and why it is so important on these, but i do not see what this will give me or others to gain from.
But i do like this topic ,sell it to me, make me understand.
Because if it was such a problem i am sure mazda/ford would of done it that way, remember these ran from 1989 to 2005 and the termostat, as always sat at the front because there as been no need to change it ,because it worked.
- BenF
- Epic Poster
Track car, yes, and hot climate cars too (e.g. those in the far east and US), less so us, but imperfections and compromise in engineering niggle me
Reading through Nutz as an example throws up (claimed) improvements with this mod, as well as less need to run a massive radiator (weight saving for me, win) and I have to say my limited knowledge of physics backs this up - I can't find fault with it yet...
...of course this is more critical for me with NO heater matrix at all...
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
- nedski
- Serial Poster
Have you done this mod yet Ben. I'm having heating problems on long track stints. Actually stints over 15mins really. I have a bigger alloy rad and twin fans. I can just about keep it under control with the cabin heater on full.
Does anybody know of a kit for the 1.6 ? Mainly to adapt the outlet at the rear of the cylinder head.
Cheers anyone
edit. found this.
http://www.bellengineering.net/index.php?cPath=5_65_240_244
Cheers anyone
edit. found this.
- BenF
- Epic Poster
I'm going to make my own mate, but I'm not there yet... Sorry
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
- nedski
- Serial Poster
Ah fair enough.
Ive found some old nutz threads for group buys but nothing current.
It's going to be a busy winter I can see coming.
Link the threads you have found
Mine used to get very hot after about 10 mins on track. I solved that with a bigger rad and an oil cooler. To be honest, I think the oil cooler is making the biggest difference. Mind you, I'm only really taking notice of oil temperatures as that is much more important than coolant temperature.
- BenF
- Epic Poster
Lazza wrote:Mine used to get very hot after about 10 mins on track. I solved that with a bigger rad and an oil cooler. To be honest, I think the oil cooler is making the biggest difference. Mind you, I'm only really taking notice of oil temperatures as that is much more important than coolant temperature.
true. until she boils over, warps the head, the waterpump cavitates and you get chronic heatsoak breaking the block
seriously though track chaps, yes your temp is a problem, but a bigger one is the imbalance. Take a laser thermo with you next time and measure the differences between cylinders...?
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
BenF wrote:true. until she boils over, warps the head, the waterpump cavitates and you get chronic heatsoak breaking the block
Again, true, but if you can keep the oil temp down then the coolant temps will be easier to keep down and it's less likely to boil over, warp the head, cavitate the waterpump, chronic heatsoak breaking the block
And yes, I know about the heat imbalance problem too. If I did more track days I'd sort out a coolant reroute to protect cylinder 4 a bit better. As it is, I just limit my stints on track to 10-15 minute sessions.
I am really interested in this Ben but i still don't see it making that much difference on a road car? maybe a motorway baby might reap the benefit?
- BenF
- Epic Poster
I think the general consensus is that in normal driving the stock system is ok, it's just when it's asked a lot of that it falls down...
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
