A G-ltd ( Mel B) arrives at wayne mansion
Postby Mazda Mender » Mon Dec 31, 2018 12:10 am
So how did this one happen...
I was looking at a daily, and was looking at something different with character ...and was looking at the smart Roadsters, plenty of home work was done on the subject including getting a lap top with software and all the hardware to be able to do anything on one the difference in BHP between the early and late version and specials etc etc....so long story after a good couple of weeks of research and asking people that owned them....stick with the devil you know as i know them inside out and have stacks of pats if needed ...
I spoted a Mk 2 import VS in green which was a auto also with 66,000 in green 1.8 cat C but all good with all the pics etc sent of the reason why and rot free...ÂŁ500, i wanted her as a daily but it finished on xmas day and was in sussex...
So i had this one on a watch also and was a little closer so i did another buy after a conversation with the owner and agreed a price with an hand shake..this time a Japanese market import G-ltd 1.8 Auto with 88,000 miles on her in not to bad of condition, i always see a good special edition Mk 1 as an investment these days she as been looked after but needs that extra love and passion, she is pretty standard which is good apart form the seats have been re-covered in cream leather and blue, the crash pad is in cream leather and the door caps, so they will all be changed, she as mazda sill skirts added a front lip spoiler and rear boot lid spoiler with brake light, a chrome style bar and a wind blocker , so they will be sorted ,alloys have been painted a graphite grey colour,so they will be repainted the correct colour, and the blue roof as been swapped for a black vinyl so that will need to be changed...
So first job was to get he passenger side window working, so the switch was taken apart and the contacts that were carboned up, so cleaned up ,back together and the window as life again all be it slow until the door cards come off and i attack all the internals of everything while in there.
There is some bubbles on the bottom sill/arch of the rear drivers side ...but nothing major that i cannot sort myself.
The bonnet is up a little tight to the front of the nose cone so looks like it as had a little kiss or nudge at some point so just needs adjustment again, the battery as been changed from a wet cell and the negative battery connection as been butchered with another aftermarket crappy thing ...so i'll sort that out the bottom bracket is toast and will need grinding out then drilling and re-tapping to fit a new one including the L shape bracket, so once in new battery tray , top holding bracket and J bolt and battery, boot carpet is missing and battery cover carpet, so they will be sorted, the wire for the rear fog light brick is wired direct to the battery and runs all the way through the cab and then another twin core washing line runs back again across the boot to the light unit. so all that will be sorted, the speakers are laughable so new ones will be fitted and a HU ...
Engine bay will get jizzed and then a full service will be done,,,cam seals,crank seal, rocker seal,CAS seal,water pump,cam belt,idle and tensioner and spring,Aux belts,oil filter,oil ,spark plugs, antifreeze, gearbox oil change and diff, fuel filter, brakes serviced and fresh fluid, tyres, alignment, under sealed and box sections,and a set of matching head lights , two new number plates and a jap spec front plate holder mount, remove the roof and check the drainage points , clean everything, check the rain rail and refit(blue with any luck) , MK 2 suspension will be fitted also, and will fit a manual box etc and convert to a 5 spd manual, and then anything else she might need as i go...
Pics to follow.
Re: The G-ltd arrives at wayne mansion
Postby Mazda Mender » Mon Dec 31, 2018 2:08 am
Some pics....
Postby blackyb » Mon Dec 31, 2018 11:09 pm
Looks like you have some more Mazda Mender fetling to get on with. Keep looking for a decent mk1 special edition but the wife wants a new car so looks like my planned addition will be on the back burner. Still mine might not be a special edition but she is very special to me.
Topic added to my follow list.
2003 1.8 SVT Sport (Why did I sell it - cos the wife said so!!!!)
Postby Mazda Mender » Tue Jan 01, 2019 12:49 am
Sorted the battery area, it was just surface batch rust ..most of it came off wirh waynes wipes,cans of the OE colour are on there way ...which is A5..negative battery connection...and battery brackets ..plus a few other things in the boot .....resprayed the jack and brace and the wheel holding bolt and holding washer.the aerail and HRW fuse box is now sercure again and the drainage to the aerail as been re-added.
Found some headlight units to be fitted as the ones that are on are odd..one is a conversion and the other is a sealed unit...found a lift motor cover.front jap number plate holder and a set of front indicator/side light conversion units....set of the OE seats on there way...found a battery tray and all bits and a gel panisonic battery...fresh bolts ready to re-fit everything....
Charged up the cordless angled drill to drill out the studs from grinding out the bolt heads and what was left of the battery securing bracket...so i'll fit all that tomorrow..
Postby Mazda Mender » Wed Jan 02, 2019 12:39 am
So the battery area is all done par the correct colour being applied when it arrives and the securing bracket to arrive yet...studs drilled out ...tray,vents, J bolt and top bracket....sound proofing re-stuck back in place..OE gel Panasonic battery waiting to be fitted also...
Made a new seal for the rear cluster as it was leaking into the boot which would of helpped in the rotting out the battery securing bracket as well as crap cheap batteries...waiting in a boot carpet and battery cover..
Changed the front headlights,as the ones that were on were odd...and all the nuts bolt and screws were re-moved ,greased and put back again....also changed the front indicator/side lights that i have converted...as the ones that were on the side lights on them were shot any way.
Also fitted a JDM number plate holder that would of been fitted in Japan ..so number plates to be cut...also found a lift motor cap .
Dug out some front and rear mud gaurds to be fitted
She as a had a good wash and wax...
Next is re-wire the rear fog light and new switch..speaker and HU...
Re: A G-ltd arrives at wayne mansion
Postby Mazda Mender » Wed Jan 02, 2019 11:53 pm
Added a battery isolater switch sorted the wiring for the rear fog lamp, the autospark that fitted this was a special kind of stupid.He had run a live wire direct off the battery to the switch through the cab and then run a twin core back through the cab from the switch which was a live return and a looped earth from behind the dash piggy backed from the switch into the boot across the boot floor ( which would of been under the carpet ) to the rear lamp...the twin core was melting on the boot floot from the heat off the back box and to top it all no in line fuse anywhere for a constant live wire...
So ripped it all out and started again correct with the wire run safer, added a new illuminated rear red fog light switch , moved the immobiliser switch for the minute, no battery on at the minute to test for a head light live for the rear fog lamp so left it in place ready to connect up..
storm
Postby storm » Fri Jan 04, 2019 12:51 am
Seems you've been busy bossman. Glad you didn't buy the smart Roadster, worst gearbox in human history. I'm enjoying this thread.
1. A car is only worth what someone is willing to pay for it, 2. Resale wont save your life in an accident, 3. Genius has limits, stupidity has none, 4. Never argue with an idiot, they will bring you down to their level & beat you with experience, 5. Growing old beats the alternative -- dying young!
Postby Mazda Mender » Fri Jan 04, 2019 10:30 am
Found a boot carpet just need the battery cover a bracket...and connected up the rear fog light...
Door cards swapped next,speakers,grease/ lube and adjust while i am in there...
Postby Mazda Mender » Fri Jan 04, 2019 9:37 pm
Found a battery cover ,but is an early one which is black and the wrong colour, Autolinkmx5 have come to the rescue and found a grey one for me,I took both inners of the doors out for a clean ,grease up/silicon lube re-fitted and adjustment so window mechs,locks and latches etc are working like new again, the cheap nasty speakers were removed and a set of sony ones fitted, another set of door cards were also fitted so the top cap is now correct and black with tear drop speaker covers, the speaker grills had a little surface rust so a quick light rub over and fresh paint applied and all fitted it back up again, i also found a JDM dash carpet so that's going on also .
Dash crash pads on there way and the battery bracket from Autolinkmx5...New HU on its way..i also noticed the interior lights are not working ,so will sort them which will be a simple case of taking the items apart and cleaning them up the copper contacts...
Need to fit a lights left on alarm, RHW switch...
Postby Mazda Mender » Sat Jan 05, 2019 9:20 pm
So interior lights working again....
Postby Mazda Mender » Sun Jan 06, 2019 1:01 am
I better do a list....
Dash crash pad.......DONE
Correct battery cover..DONE
Battery clamp bracket....DONE
Bonnet cushioners...DONE
Under bonnet fuse box sticker or new lid with one on....Done
Lights left on alarm/buzzer.... DONE
Head unit....DONE
OE rear mud gaurds...DONE
Aftermarket front mud gaurds... DONE
***Blue hood.... to arrive
Mk2 suspension.... DONE
Brakes fully serviced...DONE..2 new front calipers....DONE
Jap front and back number plates ... DONE
Water pump,cambelt,tensioner,idler and spring ......DONE
Oil filter and fresh oil....DONE
Fresh 5 year antifreeze ...DONE
Spark plugs,HT leads,Aux belts,air filter and fuel filter...DONE
Rocker seal ,CAS seal, cam seals and crank seal...DONE
Engine bay clean...DONE
HRW switch...DONE
Illumination dimmer switch...WILL NOT WORK
Cig lighter....DONE
1 x interior light....DONE
Trim clips bottom of the nose cone mouth to the air guide....DONE
***Diff and gear box oil change....
***Tyres... Uniroyal rain sports
Alignment.... Toyota....DONE
Spare door lock for the dricers barrel door....DONE
***Cut out ,weld and paint the rear drivers side and passenger...
***Underseal and box sections...
Better headlights.....DONE
Rear OEM cab Strut brace.... DONE
OE seats g-ltd...NEED CLEANING AND FITTING..DONE
Set of g-ltd floor mats....DONE
***Remove the immobilizer....
Spray spare wheel....DONE
Re seal the heater trunking clip.....DONE
New indicator and light stalk...straight versions with print on.....DONE
Brighter bulbs for the instrument gauges....DONE
New drainage tubes...DONE
Seat belt caps( drivers side)...DONE
Mk 2 seat belt tower panels, cut to take a OE rear cap brace...DONE
Mk 2 Rear seat belt tower panel on the hood frame hinge side...DONE
Seat belt tower panels (all) trim buttoms....DONE
Rocker type front fog light switch...DONE
Rocker type HRW switch....DONE
Rear boot panel solid type to glue the flimsy grey one to...DONE
Drill both sides rear seat tower roof hinge side for trim buttons...x 2 ...DONE
Handbrake adjuster clip missing...DONE
Remove rain rail and check it...looks like it has been letting in water....yeah..split,cracked,and damaged....DONE
Fit Mk 2/2.5 side sercuring brackets...DONE
Spray the middle sercuring bracket....Done
Rub down and spray the boot filler tubes shield...DONE
New weather stripes for the door tops....DONE
Clean and protection behind the front wings...DONE
Chrome door mirrors...DONE
At a later date..
***Auto to manual conversion....
Postby Mazda Mender » Sun Jan 06, 2019 11:20 pm
The engine bay as been jizzed.....
Postby Mazda Mender » Thu Jan 10, 2019 12:39 am
Engine bay done.....
Postby Mazda Mender » Thu Jan 10, 2019 1:02 am
When the heater was on screen demised i noticed there was not a lot coming through the vents, so felt down into the passenger side foot well and as i guessed air blowing cold, which means the eater trunking seals need re doing which there is 2 of, a triangle one behind the glove box and a square one further along behind the dash, the seals have a sponge /foam seal which dries out and perishes over time and turns to dust losing their seal.
So it is a case of removing the seal brackets, removing the old sponge/foam and sticking fresh on and re-fitting them and it will be better than new..
Old sponge/foam on brackets...
Old sponge/foam removed and new added ready for re-fitting....
Postby Mazda Mender » Thu Jan 10, 2019 7:56 pm
Rear mud guards sprayed and fitted...rear wheel sprayed and waiting to dry.....
Users browsing this forum: No registered users and 6 guests
