That'll never run again!
seagryhill
Re: That'll never run again!
Postby seagryhill » Tue Aug 13, 2019 10:30 pm
OK, my bad, the answer to the bracket question was found in an old image.
It's fixed to the bolt at the top right of this image. Doh!
Mk1 G-Ltd Eunos 1.8 (well sort of, all the bits except the shell)
Mk2 1.8 restored (was dead, now it's alive)
Toyota Hilux for towing MX5s on trailers
Postby Mazda Mender » Tue Aug 13, 2019 10:35 pm
1.6 mk1 engine?...jizza clean is jizza clean...i will sort you some..are you going to the clubs national?
As for the hose connection. A good light file and sand paper to clean it...on fitting a lit smear of rubber grease will help protect it as will the correct coolant.
seagryhill
Postby seagryhill » Wed Aug 14, 2019 8:43 am
1.8
Club National? That's the 14/15th September at BMM Warwick I think. Let me see if I'm allowed out of the garden for a day...
The jizza is not critical but it would be good to catch up with you guys.
Your approach to fixing the hose connection sounds a lot more sensible. I was just worried about the wall thickness getting a bit thin. All the other similar bits on the thermostat housing etc had all split. I wouldn't be surprised if the splits occurred when someone used pliers to pull the hoses off given that it's a pressurised system. I've picked up a cooling system pressure tester so I intend to check the system before it goes into a shell.
Users browsing this forum: No registered users and 9 guests
