1995 G-Limited ***RESTORATION***Rebuild
Lumphammer
Re: 1995 G-Limited ***RESTORATION***Rebuild
Postby Lumphammer » Sat Sep 05, 2020 6:49 pm
These were the type of defects I was getting, you can only see them when the solvent from the primer hits causing a slight rise in the surface. I've dug them out with a scalpel and filled with dolphin glaze, it works well but took ages
I bought this from eBay, it's a cheap weather station thing but it has humidity which is exceptionally useful together with the dehumidifier. Don't know how accurate it is but it seems right-enough, for the ÂŁ7 it cost brilliant!
Final wet sand. It's had two guide coats due to all the defects popping up everywhere I'd lost confidence in the first
Paint and clearcoat. A b*****d tiny moth fell into the second clear, i pulled it out alright but there's a 1/4" wide bit of browny dust forever in it now, really annoying but that's life...
I put three coats of clear on it, looks very nice. Will be wet sanding it in a few weeks when the cars back together
In case anyone is interested in number of rattle cans for a hard top:
1 x Plastic primer (for burn through areas)
4 x Upol grey primer
3 x Metallic basecoat
5 x Upol clearcoat
Lumphammer
Postby Lumphammer » Sat Sep 12, 2020 7:53 pm
Had a good day today. Cleaned the crazy amount of painting filth from the garage and got the car off the rotisserie and back onto axle stands for reassembly.
I used the engine crane to get the shell up there but it was dodgy as **** and I didn't want to do it again so i built another trestle so i could use the jack to gradually inch it down swapping front to back and lowering the bar each time. I'd definately do it this way next time!! :-D
Going to put the loom and fuel tank back in tomorrow :dance:
Postby blackyb » Sat Sep 12, 2020 9:12 pm
Cracking work buddy.
Lumphammer
Postby Lumphammer » Tue Sep 15, 2020 11:04 pm
The front side tab had snapped off the ABS air guide, i used a soldering iron to tack weld it in place and then scratched and swiss cheesed it to bond well to fibreglass
I had to bend a bit of alu to make the fibreglass follow the corner properly, i was going to take it off afterwards but it'd stuck so well i left it in place
I was doing some stuff with POR15 so i painted it to blend in better - largely pointless :-D
Air guide in place and the front of the bumper bar painted in POR15. The bumper reinforcements were cleaned back to stell, kurust, etch primer and black gloss
Painted the boot in POR15, I'd originally intended to have it body colour but I'd lost the will to live spray painting in rattle cans! :lol:
The brake servo had some surface rust, I sanded it back, kurust, etch prime and black gloss. Alu master cylinder just cleaned back. The brake balance bracket is being done at the moment
Main loom and cabin loom in place. I'm doing this an unconventional way because i'll have a very minimal dash, it'll be done so it can be put back to normal but the insides of the dash will be a bare minimum
The secondhand carpets were scrubbed and have come out very nice. All the marks have gone and should smell very "fresh" :-D
Lumphammer
Postby Lumphammer » Thu Sep 17, 2020 11:30 pm
Had a good couple of days, I needed two small bits of underfelt so had to order some. Got carried away and replaced all of it - these bits are tacked to the body with a few sprays of contact adhesive, the rest is stuck to the carpet.
The carpet has come up a treat, I got it on eBay from a guy who'd taken it from a 10AE. I asked Wayne for advice and he said put the carpet in before the dash, I thought "I'll just put the bar in to make it easier to get stuff connected..." not realising the bar gets in the way of the carpet - so had to take it out again :lol:
^look at those original 90's floor mats!! They're so bad - I love them :-D
Cleaned out the blower, was proper manky in there. Made some new foam gaskets.
Rear of the car mostly back together, there's some panel gap issues but I think I know how to fix them
Starting to look a bit like a car again!
fujikun
Postby fujikun » Fri Sep 18, 2020 5:54 am
:text-coolphotos: cracking job, coming together now.
Postby Mazda Mender » Fri Sep 18, 2020 6:24 am
:handgestures-thumbup:
Lumphammer
Postby Lumphammer » Fri Sep 18, 2020 8:51 pm
All of the original bumper reinforcement screws had rotted to bits, found some oddball self tappers I'd saved for a rainy day years ago which with 5mm stainless washers fitted perfect
Put the doors on. Did it on my own using a couple of towels and then the catch plate to act as a third hand - worked but would have been much easier with a second person. I think the spats look good.
Front bumper went on fine
Got an interior, going to use the spray dye on the seats. They're in good condition but really faded. Look at those mats...! :-D
Postby Mazda Mender » Sat Sep 19, 2020 8:11 am
:coffee: :handgestures-thumbup:
Natehd9
Postby Natehd9 » Sun Sep 20, 2020 8:51 pm
Looking amazing, congratulations! Bet you can't wait to get it all back together!
:obscene-drinkingcheers:
