My story so far
Re: My story so far
Postby Mazda Mender » Fri Mar 18, 2016 7:38 am
I know the guide and will contact Andrew, as we removed it from off here, as it is far easier and safer to crack the drop links, the bolts that hold the anti roll bar bush brackets are getting on more so with the rears that are open to everything, the fronts bolt down to a captive nut in the front rails, so if any of these snap which i have seen a lot, you will have a lot of work on your hands drilling out and re-tapping,which for the home fettler on a drive thats playing can be out of their comfort zone, where as the drop link bolt and nut is easier to get to and if you need to cut it off, you just need to re-place the nut and bolt.
Re: My story so far
Postby Mazda Mender » Fri Mar 18, 2016 7:49 am
GlennyGills
Re: My story so far
Postby GlennyGills » Fri Mar 18, 2016 1:32 pm
Thanks for the advice. Now I can see what to crack and reset.
:handgestures-thumbup:
GlennyGills
Re: My story so far
Postby GlennyGills » Tue Mar 29, 2016 12:44 pm
Well I had a go at cracking the nuts as specified and cant see any difference.
Before 1
Before 2
Droplinks and Shock Bolts
After 1
After 2
Tyre top to wheel arch still approx. 4"
:confusion-confused:
Silly question
Pincherrn were these std springs ??
John
Re: My story so far
Postby Mazda Mender » Tue Mar 29, 2016 11:20 pm
They are not OE springs? what are they, thats where the problem is.
GlennyGills
Re: My story so far
Postby GlennyGills » Thu Mar 31, 2016 8:07 am
Hi Wayne, I understand they are std Mk2 springs, bought from Pincherrn sometime ago.
Can someone take look at pictures 415 & 416 above and tell me if the springs are fitted the correct way round, is there a wrong way to fit them??
Thanks
John
GlennyGills
Re: My story so far
Postby GlennyGills » Mon Apr 04, 2016 12:38 pm
Comparing my ride height to a normal Mk1 ride height, it seems that fitting the MK2 suspension has raised the rear end by about 2-3 inches. Is it a just a case of chopping of some of the spring to drop the rear or is there more to consider ?
I guess the next question would be how do I know much to chop off ? Any help ?
Pincherrn
Re: My story so far
Postby Pincherrn » Mon Apr 04, 2016 9:58 pm
Only just seen this. I was told when I bought them that they were standard Mk2 shocks and springs. I never saw the car they came off. They did look like standard springs. I never ever used them on a car either Exocet or S Special.
Colin
MEV Exocet.
1995 1.8 Mk1 White Roadster. S Special Type I.
Exocet build thread - http://www.mazdamenders.net/forum/viewtopic.php?f=35&t=1138
http://www.jansholistics.co.uk/
Re: My story so far
Postby Mazda Mender » Mon Apr 04, 2016 10:10 pm
The springs are the issue, they are not OE springs, the tension rate on them must be high so making her sit high.
GlennyGills
Re: My story so far
Postby GlennyGills » Tue Apr 05, 2016 12:25 pm
Hi Wayne, Pincherrn believes they are std springs and I bought them from him. Have you seen something different.
When I put the MK1 and MK2 units side by side they were the same length. I have been doing a bit of checking and the ride height looks the same as some others that have been converted. I will have a go at jacking up the car putting it on stands and then taking wheels off, loosening bolts jack up empty suspension and tighten under load as recommended. I did try opening and closing the bolts whilst the car was on ramps.
BTW the car feels a lot smother on the road if perhaps a bit twitchy, I have not yet had the alignment re-done, trying to resolve ride height first.
ps many thanks for the help.
Re: My story so far
Postby Mazda Mender » Thu Apr 07, 2016 12:30 pm
They are defo not OE springs.
GlennyGills
Re: My story so far
Postby GlennyGills » Wed Apr 20, 2016 12:34 pm
Well car gone for MOT today, if no surprises, I think I will be having some of the Meisters from the Autolink special offer.
GlennyGills
Re: My story so far
Postby GlennyGills » Wed Apr 20, 2016 6:15 pm
No problem with the MOT, so I guess time to get on the Web and order the meisters
GlennyGills
Re: My story so far
Postby GlennyGills » Thu Apr 21, 2016 12:33 pm
Meisters ordered, is there any particular settings to use for them before fitting to the car.
Yolo
Epic Poster
Re: My story so far
Postby Yolo » Mon Apr 25, 2016 10:29 pm
:handgestures-thumbup: Mine are fitted straight from the box because as far as I have read they are pretty well setup. after that it is up to you to adjust as the mood takes you :auto-layrubber:
Mk 1 Eunos 1.6 Silver
Getting there slowly
viewtopic.php?f=35&t=4699
