eunos is back
roadster1980
Re: eunos is back
Postby roadster1980 » Wed Dec 03, 2014 4:23 pm
This is caused by not fully cured paint and water and frost we have had this before with a lacquer and putting a heat lamp will get rid of it but not permanent, only solution is to rub it back down re coat it and seal it with lacquer, let it dry fully in a warm environment and it should be ok
td-05 turbo@.6bar 190.8hp
Build thread
viewtopic.php?f=35&t=1399
fujikun
Re: eunos is back
Postby fujikun » Wed Dec 03, 2014 4:39 pm
thanks for the advice, i never put any laquer on it, another tin to buy then. will it be ok for now? might be a wee while till i get round to it.
Re: eunos is back
Postby Lazza » Thu Dec 04, 2014 10:46 am
As for the condensation - you have a water leak letting in water somewhere. Have you checked the hood drain tubes and sill drains?
fujikun
Re: eunos is back
Postby fujikun » Thu Dec 04, 2014 9:38 pm
yes lazza, when i changed the hood i fitted new drains, there clear so are the sill holes i poked them out when i was painting the underside,
i think mainly the car has been off the road for 6 weeks, the inside of the windscreen was running, i never noticed any leaks when i was using it.
obviously with the winter coming on the air is damp and if the sun shines in the morning i think the air inside heats then condenses.
Re: eunos is back
Postby Lazza » Fri Dec 05, 2014 9:57 am
An MX5 shouldn't suffer from damp any worse than any other car. If it is then there is water getting in somewhere. Have you checked the boot? Rear light seals & Frankenstein bolt seals are common failure spots too.
Re: eunos is back
Postby Mazda Mender » Fri Dec 05, 2014 11:22 am
footwells, under the seats,rain rail?
fujikun
Re: eunos is back
Postby fujikun » Sat Dec 06, 2014 3:11 pm
hi, thanks for the replies.
the rain rail was perfect when i changed the hood, the floors are dry, i am pretty sure its just condensation. its not garaged.
got the new tyres fitted today so i am back on the road.
pics are ice inside, windscreen, and the newly wired hrw doing its job.
Re: eunos is back
Postby Mazda Mender » Sat Dec 06, 2014 7:34 pm
Although you will never make these roadsters air tight,It should not be anywhere near that bad inside, you need to check around because something is wrong.
fujikun
Re: eunos is back
Postby fujikun » Sat Dec 06, 2014 8:31 pm
i guess the window rubbers at the top are not great, other than that i dont know.
Re: eunos is back
Postby Lazza » Sat Dec 06, 2014 9:18 pm
Have you checked for damp under the carpets (no good checking on top), in the footwells and being the seats and also in the boot, again under the carpet. Finding the wettest place is a clue to how the damp is getting in.
fujikun
Re: eunos is back
Postby fujikun » Sun Dec 07, 2014 12:11 pm
hi lazza,
yes the car inside is as dry as a bone, those pics is an accumulation of about 3 days hard frost up here, when i took the car out and got the heater on and everything
vapourised it was ok.
fujikun
Re: eunos is back
Postby fujikun » Wed Dec 10, 2014 11:33 am
after all the underside work, he`s back on the road, if you can see passed the paint, its a fairly good sound car.
i`ll keep at it.
fujikun
Re: eunos is back
Postby fujikun » Tue Dec 23, 2014 6:00 pm
first time this has happened in the rain, but i finished night shift this morning, jumped in and wet bum driving home.
raining now so been out with the torch and its dripping from the top of the quarter window seal and running down and sitting in the bucket of the seat.
i guess i will have to change the seal. is it easy to do?
the drip is circled red.
Re: eunos is back
Postby flea » Tue Dec 23, 2014 6:15 pm
If it's split on the outside you can fix with a little super glue. Also make sure your window is not going up to much. The water collects in that top section & drains through the rubber down to the bottom
wazza99
Re: eunos is back
Postby wazza99 » Wed Dec 24, 2014 4:22 pm
You can also run a trombone brush down that channel, feed in from collector at top, gently push through and it pops out at bottom front edge of door. Perhaps that tube is blocked so causing water to overflow the collector. Amazing what uses those brushes come in for !
