1996 Uk spec Rebuild (we hope)
Re: 1996 Uk spec Rebuild (we hope)
Postby Mazda Mender » Thu May 25, 2017 6:40 am
:text-coolphotos: :text-goodpost: :handgestures-thumbup: :coffee:
vindaloo
Postby vindaloo » Thu May 25, 2017 10:12 pm
What an excellent job you are doing, I wish I had a tenth of your skills
2008 NC 2.0 Sport
Engine/Driveline: BBR/AT Power 42mm 'Super 225' individual throttle body conversion, BBR Super 200 cams, BBR EcuTek remap, Racing Beat 4-1 stainless steel exhaust manifold, GWR Roadstersport 2.5 inch stainless mid pipe with 200 cell sports cat, GWR Roadstersport 'Super Q' silencer, Supertech uprated valve springs, Supertech Ti valve spring retainers, K&N air filter in modified OEM housing with 3 inch MAF housing, Odula RS intake scoop, modified breather/PCV system with catch can, Competition Clutch 5.35kg lightweight flywheel, Flyin' Miata Level 1 clutch
Chassis: Ohlins 'Road&Track' DFV coilovers, Eibach anti-roll bars with Superpro bushes, ILM chassis braces (front/middle/rear lower), Auto-Exe Japan front upper strut brace
John&Luke
Postby John&Luke » Sat May 27, 2017 10:20 am
vindaloo wrote:What an excellent job you are doing, I wish I had a tenth of your skills
Thanks. But you do!!! the majority of it is common sense and patience. Just start with small jobs and go on from there and take your time.
All the knowledge you need is on this forum, just ask if you get stuck.
John&Luke
Postby John&Luke » Mon May 29, 2017 7:47 pm
Work continues, So managed to get the bonnet, boot, both bumpers, rear number plate panel and mirrors, top coated today. Nice to see some red panels after the grey primer.
Pleased to be making progress slowly. Couple of photo's (hard to get the camera to focus when the paint is so shiney :) Well that my excuse!
John&Luke
Postby John&Luke » Mon Jun 12, 2017 10:04 pm
So, busy weekend prepping the main bodyshell for top coating. Final coat of primer and then lots more flatting down with 600 grit Wet and Dry. Had 'bath' fingers afterwards (you know when all the skin goes wrinkly due to being in water to long!)
So photos of the shell ready to go.
Then re mask the car (easier said than done) mix paint, play loud music, cross fingers and hope all the work has been worth it!!!!
The results after 4 litres of Classic Red.
Really pleased with how the rear arches have come out :-D
Finally, arch spats, doors and wing,
So feels like a milestone reached (couple of months behind schedule) but very pleased with the results. Panels all look nice and straight. Have learnt so much in the process so far.
Loving the colour depth of the classic red. Looks almost a 'Ferrari Red'. So then started comparing it to some colour charts and guess what , a very close match to Ferrari Rosso Corsa. Who would have thought
Next job quick flat and polish and reassembly. Hopefully I can remember where all the bits go/came from.
:bow-yellow: :bow-yellow: :bow-yellow: :bow-yellow: :bow-yellow: :handgestures-thumbup: :coffee:
GustavU
Postby GustavU » Tue Jun 20, 2017 9:01 am
:text-coolphotos:
I think it's going to look real good when it's done.
John&Luke
Postby John&Luke » Sat Jul 08, 2017 9:22 pm
Spend a nice day in the sun today Waxoiling my 5. Then started the process of reassemble.
No one at home pleased I'd spend all day in the man cave but hay ho, somethings are important.
Got her back home and took these photos
Went for a 'small' stick on plate so not to spoil those nice lines
Postby Mazda Mender » Wed Jul 12, 2017 7:00 am
John
You have lost some of your build pics because of photof*ckit....see yellow notice at the top bud or site news section, i am also at there ransom, grrrrrr
John&Luke
Postby John&Luke » Wed Jul 12, 2017 9:56 pm
Mazda Mender wrote:John
MM, Yes I know.
Can I have edit rights to my posts? if so i post images on a different site hopefully reinstate the images.
Postby Mazda Mender » Thu Jul 13, 2017 7:23 am
I'll get hold of our IT chap to sort it for you buddy, i have no idea how to do it,then attach them or drag and drop from what ever, phone/harddrive on here bud, it will auto re-size and lock in for good then, i have a major head ache with it also at the minute.
John&Luke
Postby John&Luke » Sat Jul 22, 2017 1:31 pm
Received my replacement door/window seals today. Went for Mazda genuine replacements as apposed patten parts. Bit more expensive but figured its a key part and needs to look right.
Easy job to fit, makes a big difference. Pleased.
Also fitted some IL Motorsport bonnet lifters.
Rewired my rear fog as planned to use the offside reserving lens with a Red LED bulb. :coffee:
John&Luke
Postby John&Luke » Sun Aug 13, 2017 12:53 pm
Busy Busy,
Always wanted a White 5 so purchased the next project in the week.
Work to do but that's what I seem to enjoy :-D
As its going to be sat for some time decided to swop the wheels that came with the White 5 (TSR Blades with 205 Yokohama's) onto my Red one!
Then had my own little car show :-D
Postby Mazda Mender » Sun Aug 13, 2017 11:12 pm
Whats the to do list on the white one buddy????
John&Luke
Postby John&Luke » Mon Aug 14, 2017 8:12 pm
M-m,
This looks to be a reasonable low miler. MOT fix's include front brake overhaul, track rod ends. Replace silly quick release steering wheel boss that has loads of play in it. Nearside rear sill welding and a bit of plating along the sill, as expected.
This will be phase 1. then longer term I'm thinking new sills rear arches, may need a new NS front wing. Then I was thinking about repainting in Old English White ???? and going down a retro look maybe steel wheels, chrome racing mirrors de tango indictors, lose the side repeaters , chrome roll hoop etc. On the interior remove the centre console and centre 'tombstone' heater control panel.
Not sure if this has been done before? whats peoples views on Old English White?
Postby Mazda Mender » Mon Aug 14, 2017 9:09 pm
Old english white with red interior...the mk2 white is a nice white.
