My 91 us special BRG rolling resto
Wardy
Re: My 91 us special BRG rolling resto
Postby Wardy » Tue Feb 23, 2016 2:11 pm
Great progress!
Attachments working fine for me.
Postby Mazda Mender » Wed Feb 24, 2016 8:33 am
And me.
Brgdane
Postby Brgdane » Thu Mar 03, 2016 10:28 am
Still alive :-)
But it has been very cold recently. I managed to get the new manifold heatwrapped and installed. Also a brand new cat in stainless.
It is so quiet now, i guess i have to install a new loud muffler soon.Image
Found a nice tonneau cover, love the sleek look.
Trying to get all sorts of small jobs sorted on the car, with what i have laying around. Funds are running a bit low at the moment, so i will have to hone my fabrication skills :-)
Oh and here is my new co- driver, arriving next week.Image
Brgdane
Postby Brgdane » Thu Mar 03, 2016 10:29 am
Postby blackyb » Thu Mar 03, 2016 7:37 pm
Just run in maybe but a long way down the track to being a serial mender, great work going on there.
Brgdane
Postby Brgdane » Thu Mar 03, 2016 10:03 pm
Thanks blacky, it means a lot to me
By the Way, i found a working cure for the mix of dintrol, old leaves and general s... In the engine bay: spray with heavy duty degreaser, agitate with brush leave for 15 min. And finaly pour several pots of boiling water over the infected area. In the last picture to the right you can clearly see, that the last pot was used for my coffee
Brgdane
Postby Brgdane » Thu Mar 10, 2016 8:53 pm
The speaker grills were in a sorry State. So i cut 2 pieces of oak on my milling machine, put in a piece of stainless mesh and hit gently with a big hammer untill flush. Trim the edges with a tin snip, a Dab of epoxy and voila :-)
Grilles for the cost of 1ÂŁ each.
Postby blackyb » Sat Mar 12, 2016 7:57 pm
Proper mending.
Brgdane
Postby Brgdane » Thu Mar 17, 2016 5:49 pm
So time for the brakes, i noticed there was some lip on the discs.
And a little rattling under braking. Surely the P.O has neglected this a bit. Got everything apart and cleaned up. Pistons are corroded on the inside but moves allright. I wil take the callipers apart when i upgrade the brakelines later.
A touch of paint and all done exept for this:
No springs installed between the pads, i guess thats where the lip came from :-(
Postby Mazda Mender » Fri Mar 18, 2016 8:24 am
Looks like you need a full set of anti rattle springs/lift off springs, Autolinkmx5 sell them, did you use red rubber grease in the slider wells on the carrier?
Brgdane
Postby Brgdane » Fri Mar 18, 2016 9:26 am
Lift off springs are on the way. i cleaned up the small clips and reused them, is that a bad idea?
I havent greased anything yet, waiting for the paint to cure,copper grease is at hand. This is just a test muck up, i have never done brakes before. So tricks and hints are more than welcome :-)
Postby Mazda Mender » Sun Mar 20, 2016 10:18 pm
Don't forget the rubber grease for the slider pins, but using the old slider clips is fine as long as they are ok.
Brgdane
Postby Brgdane » Mon Mar 21, 2016 5:12 pm
I have used liberal amounts if copper-grease on the pins
Postby Mazda Mender » Mon Mar 21, 2016 9:59 pm
Brgdane wrote:I have used liberal amounts if copper-grease on the pins
NNNNoooooooooooooooooooooooooooooooo not copper slip on the slider pins, it will do the opposite to what you think it should, with the heat it will turn to a goo, sticky mud and will affect the rubber compound and turn it hard and shrink, red rubber grease on the slider pins and copper slip on the slider clips, shims,pot, handbrake arms etc.
Brgdane
Postby Brgdane » Mon Mar 21, 2016 10:20 pm
Thanks, i will rinse and regrease
