From neglected and unloved to be reborn again and enjoyed....... A Mk2.5 refresh story with 15,100 miles
She is a barn find in a nut shell, 54 plate 1.6 MK 2.5 5 speed manual that was left neglected and ended up greener than the shrubs that were keeping her safe....
Darrel and Vicky are the owners that knew of her and after many years of trying to get her, finely got offered her after 9 years of sitting in her army camouflage.
The lady that owned her ...owned 2 ,and for some reason they ended up getting parked up on the drive and never used again, the lady sadly passed away and the family offered the now grim looking mazda to the pair of them but now as a none runner, which they bought, in around November of 2018....
Darryls comment....
"Previous owner was a regular customer in my Wife's shop. She had 2 Mx5's she used regularly but in about 2008 she was no longer fit to use them and they where pulled onto her drive and never used again. We repeatedly offered to purchase them off her but she always said 'one day I will be able to use them again'. Last year sadly she passed away, her family came into the shop and offered us the chance to buy the last remaining car. So we did, we had to cut down overgrown shrubs to be able to get her off the drive but now she is ours".
So they got her towed home and began the bit of a clean in and out and started the process of trying to get to the bottom of the none start issue, thats where i personally came in after Darryl contacted through the FB side on menders, so back and forth with messages and the odd phone call until we got her collected and dropped here at Wayne mansion, to resolve the none start issue and a service, it was clear from reversing her off the low loader she needed a lot more than a quick start and service...
Body is solid , no rust, bar some surface rust underneath from being stood on soil in shrubs for that amount of time, brakes want binning, there is still signs underneath of the growth she was in, so that will all need sorting ,protecting ,undersealing and box sections injecting with cavity wax, engine by needs a major Jizza clean, water pump and cam etc will need doing as she is nearly 20 years young and been stood for nearly 10 of those,tryes are shot, and need to check everything, hoses, pipes, boots, bushes etc etc.
So now Darrly understands what i was getting at that she needs this work, regardless whether i do it or someone else, he agreed that the investment does need putting into her as she sits with only 15,100 mile on here, so is well worth the effort and spend to bring her back to where she should be...
So this will be the trails and tribulations of the rebirth/refresh of a soon to be a very very nice with very low miles MK 2.5 1.6 UK spec Mazda Mx-5 rag to riches barn find.
Darryls comment....
Re: From neglected to reborn.... A mk2.5 story
Sounds like someone is going to be a busy boy!! Looking forward to the pics
DAVE
First pics added Dave'o
Still wish it was in my garage either before or after Wayne has done his bit.
Going to make a cracking MX
So she is giving us nowt through the fault reader from the ECU via OBDII, as far as she is concerned there is nothing wrong, but she will not fire, so all sensors swapped, cam,crank, AFM,coil pack, leads, heat sensor, air sensor, plugs ( there was a set of strange plugs in there),check timing and belt, we have spark ,we have fuel to the engine bay so the pump is fine?( could be weak?), so onto fuel and on changing the fuel filter it seemed a strange colour , pink'ish red???so on the phone to Darryl.
He removed the pump and sucked out all the old fuel added 10 ltrs of fresh and some cleaning additive, 1/2 a tin to 1/4 of a tank, so out came that fuel, we put some in a flat tin and lite it to see just how combustible it was....it lite and smoked off black with the additive/oil clearly congealing in the bottom of the tin.
So fresh fuel, fresh filter, but still a none start, so we sprayed direct into the air inlet to see if she will run, and she fired and ran, which means the blockage is either the diaphragm? fuel rail ? or injectors ? starving the engine of fossil fuel, or a weak fuel pump?.
So parts ordered of a breaker for testing, in the mean time i hit the engine bay with some jizza, 1 because she needed it and 2 because i will be taking it all apart to sort, so its better clean....
Parts are also on there way to sort the braking system...new disks and pads, will check the condition fully of the calipers while they are apart if any new ones are needed and change the fluid which i will be checking boots and bushes at the same time , water pump and belts are on there way from Autolinkmx5 so a she will be getting a full hit ans service, and what ever's needed as we go.
Any way onto the pics so far...
- IMG_20190729_225529.jpg (455.29 KiB) Viewed 10898 times
- IMG_20190729_225519.jpg (480.56 KiB) Viewed 10898 times
- IMG_20190729_225503.jpg (499.48 KiB) Viewed 10898 times
- IMG_20190729_173541.jpg (509.23 KiB) Viewed 10898 times
- IMG_20190729_173525.jpg (573.35 KiB) Viewed 10898 times
- IMG_20190729_173519.jpg (581.66 KiB) Viewed 10898 times
- IMG_20190729_173505.jpg (473.63 KiB) Viewed 10898 times
- IMG_20190729_173503.jpg (559.19 KiB) Viewed 10898 times
- IMG_20190729_173451.jpg (435.2 KiB) Viewed 10898 times
- IMG_20190729_173447.jpg (468.31 KiB) Viewed 10898 times
- IMG_20190729_173444.jpg (582.58 KiB) Viewed 10898 times
- IMG_20190729_173419.jpg (481.59 KiB) Viewed 10898 times
- IMG_20190729_173416.jpg (527.17 KiB) Viewed 10898 times
- IMG_20190729_173403.jpg (535.07 KiB) Viewed 10898 times
- IMG_20190729_173357.jpg (476.63 KiB) Viewed 10898 times
- IMG_20190729_173352.jpg (557.61 KiB) Viewed 10898 times
- IMG_20190729_173340.jpg (557.65 KiB) Viewed 10898 times
- IMG_20190729_173332.jpg (546.98 KiB) Viewed 10898 times
- IMG_20190729_173328.jpg (510.23 KiB) Viewed 10898 times
- IMG_20190729_173320.jpg (570.65 KiB) Viewed 10898 times
- IMG_20190729_173314.jpg (519.75 KiB) Viewed 10898 times
- IMG_20190729_173310.jpg (518.97 KiB) Viewed 10898 times
- IMG_20190729_173302.jpg (574.79 KiB) Viewed 10898 times
- IMG_20190731_184853.jpg (591.7 KiB) Viewed 10898 times
- IMG_20190731_184836.jpg (791.03 KiB) Viewed 10898 times
- IMG_20190731_184829.jpg (577.61 KiB) Viewed 10898 times
- IMG_20190731_184823.jpg (581.35 KiB) Viewed 10898 times
- IMG_20190731_184817.jpg (583.24 KiB) Viewed 10898 times
- IMG_20190731_184813.jpg (641.69 KiB) Viewed 10898 times
- IMG_20190731_174458.jpg (632.66 KiB) Viewed 10898 times
- IMG_20190731_174455.jpg (583.86 KiB) Viewed 10898 times
- IMG_20190731_173358.jpg (607.98 KiB) Viewed 10898 times
- IMG_20190731_173348.jpg (620.71 KiB) Viewed 10898 times
- IMG_20190728_143808.jpg (599.42 KiB) Viewed 10898 times
- IMG_20190728_143802.jpg (562.58 KiB) Viewed 10898 times
- IMG_20190728_143759.jpg (516.12 KiB) Viewed 10898 times
- IMG_20190728_143754.jpg (587.14 KiB) Viewed 10898 times
- IMG_20190727_184329.jpg (563.07 KiB) Viewed 10898 times
- IMG_20190727_184319.jpg (562.77 KiB) Viewed 10898 times
- IMG_20190727_184310.jpg (589.06 KiB) Viewed 10898 times
- IMG_20190727_184302.jpg (628.68 KiB) Viewed 10898 times
- IMG_20190727_184203.jpg (459.85 KiB) Viewed 10898 times
- IMG_20190727_184243.jpg (650.37 KiB) Viewed 10898 times
- IMG_20190727_184239.jpg (635.18 KiB) Viewed 10898 times
- IMG_20190727_183842.jpg (514.35 KiB) Viewed 10898 times
- IMG_20190727_184109.jpg (400.49 KiB) Viewed 10898 times
- IMG_20190727_184100.jpg (511.18 KiB) Viewed 10898 times
- IMG_20190727_184051.jpg (551.74 KiB) Viewed 10898 times
- IMG_20190727_184046.jpg (541.91 KiB) Viewed 10898 times
- IMG_20190727_184044.jpg (468.24 KiB) Viewed 10898 times
- IMG_20190727_184039.jpg (626.42 KiB) Viewed 10898 times
- IMG_20190727_184036.jpg (588.02 KiB) Viewed 10898 times
- IMG_20190727_184030.jpg (527.5 KiB) Viewed 10898 times
- IMG_20190727_184028.jpg (459.16 KiB) Viewed 10898 times
- IMG_20190727_184024.jpg (584.58 KiB) Viewed 10898 times
- IMG_20190727_184021.jpg (594.84 KiB) Viewed 10898 times
- IMG_20190727_184017.jpg (609.69 KiB) Viewed 10898 times
- IMG_20190727_184013.jpg (583.28 KiB) Viewed 10898 times
- IMG_20190727_183825.jpg (405.19 KiB) Viewed 10898 times
- IMG_20190801_174415.jpg (546.86 KiB) Viewed 10898 times
- IMG_20190801_174418.jpg (557.92 KiB) Viewed 10898 times
- IMG_20190801_174424.jpg (580.29 KiB) Viewed 10898 times
- IMG_20190801_174427.jpg (627.08 KiB) Viewed 10898 times
- IMG_20190801_174430.jpg (607.84 KiB) Viewed 10898 times
- IMG_20190801_174433.jpg (505.32 KiB) Viewed 10898 times
- IMG_20190801_174435.jpg (582.67 KiB) Viewed 10898 times
- IMG_20190801_174437.jpg (565.79 KiB) Viewed 10898 times
- IMG_20190801_174443.jpg (600.1 KiB) Viewed 10898 times
- IMG_20190801_174446.jpg (558 KiB) Viewed 10898 times
- IMG_20190801_174449.jpg (548.76 KiB) Viewed 10898 times
- IMG_20190801_174451.jpg (492.22 KiB) Viewed 10898 times
- IMG_20190801_174453.jpg (537.41 KiB) Viewed 10898 times
- IMG_20190801_174457.jpg (569.53 KiB) Viewed 10898 times
- IMG_20190801_174506.jpg (614.54 KiB) Viewed 10898 times
- IMG_20190801_174512.jpg (475.96 KiB) Viewed 10898 times
- IMG_20190801_174509.jpg (517.25 KiB) Viewed 10898 times
- IMG_20190801_174517.jpg (507.07 KiB) Viewed 10898 times
- IMG_20190801_174521.jpg (516.66 KiB) Viewed 10898 times
- IMG_20190801_174525.jpg (540.39 KiB) Viewed 10898 times
- IMG_20190801_174531.jpg (499.44 KiB) Viewed 10898 times
- IMG_20190801_174535.jpg (545.1 KiB) Viewed 10898 times
- IMG_20190801_182012.jpg (601.25 KiB) Viewed 10898 times
- IMG_20190801_184107.jpg (573.12 KiB) Viewed 10898 times
- IMG_20190801_184110.jpg (610.39 KiB) Viewed 10898 times
- IMG_20190801_184114.jpg (537.42 KiB) Viewed 10898 times
- IMG_20190801_184116.jpg (614.54 KiB) Viewed 10898 times
- IMG_20190801_184118.jpg (614.41 KiB) Viewed 10898 times
- IMG_20190801_184122.jpg (573.58 KiB) Viewed 10898 times
- IMG_20190801_184124.jpg (629.87 KiB) Viewed 10898 times
- IMG_20190801_184128.jpg (511.55 KiB) Viewed 10898 times
- IMG_20190801_184130.jpg (608.74 KiB) Viewed 10898 times
- IMG_20190801_184824.jpg (597.17 KiB) Viewed 10898 times
- IMG_20190801_184828.jpg (567.53 KiB) Viewed 10898 times
- IMG_20190801_184831.jpg (470.01 KiB) Viewed 10898 times
- IMG_20190801_185355.jpg (666.33 KiB) Viewed 10898 times
- IMG_20190801_185359.jpg (585.47 KiB) Viewed 10898 times
- IMG_20190801_185402.jpg (491.67 KiB) Viewed 10898 times
- IMG_20190801_185404.jpg (462.81 KiB) Viewed 10898 times
- IMG_20190801_185407.jpg (568.42 KiB) Viewed 10898 times
- IMG_20190801_185411.jpg (505.01 KiB) Viewed 10898 times
- IMG_20190801_185413.jpg (502.94 KiB) Viewed 10898 times
- IMG_20190801_185416.jpg (454.04 KiB) Viewed 10898 times
- IMG_20190801_185419.jpg (540.61 KiB) Viewed 10898 times
- IMG_20190801_185421.jpg (465.62 KiB) Viewed 10898 times
- IMG_20190801_185424.jpg (537.99 KiB) Viewed 10898 times
- IMG_20190801_185427.jpg (443.03 KiB) Viewed 10898 times
- IMG_20190801_185432.jpg (610.53 KiB) Viewed 10898 times
- IMG_20190801_185435.jpg (623.12 KiB) Viewed 10898 times
- IMG_20190801_185444.jpg (602.52 KiB) Viewed 10898 times
- IMG_20190801_185447.jpg (529.1 KiB) Viewed 10898 times
- IMG_20190801_185451.jpg (515.72 KiB) Viewed 10898 times
- IMG_20190801_185453.jpg (521.79 KiB) Viewed 10898 times
- IMG_20190801_185457.jpg (496.56 KiB) Viewed 10898 times
- IMG_20190801_185459.jpg (510.93 KiB) Viewed 10898 times
- IMG_20190801_185502.jpg (532.08 KiB) Viewed 10898 times
- IMG_20190801_185507.jpg (467.48 KiB) Viewed 10898 times
- IMG_20190801_185509.jpg (521.13 KiB) Viewed 10898 times
- IMG_20190801_185511.jpg (558.65 KiB) Viewed 10898 times
- IMG_20190801_185513.jpg (588.72 KiB) Viewed 10898 times
- IMG_20190801_185518.jpg (662.4 KiB) Viewed 10898 times
- IMG_20190801_185549.jpg (481.96 KiB) Viewed 10898 times
Re: From neglected and unloved to be reborn again and enjoyed....... A mk2.5 story with 15,100 miles
She lives, and runs dead sweet and was a combination of a number of things, after swapping out all the fuel side in the engine bay, she still did not run, so not a blockage ..., so back to the fuel pump, and that was problem number one, someone had fitted the wrong fuel pump while messing to get her up and running, they had fitted a MK 2 1.6 pump rather than a MK 2.5 1.6 pump, the MK 2.5 pump is pressure regulated on the pump, where as that MK 2 1.6 version is not, so fuel pressure was the first issue, next was the ECU playing up, but no damp or water? so Darryl had already got one in the boot, so everything changed, all locks etc, and she lived first turn...so the service was fully done, every as been lubed up hinges ,joints,locks etc etc ,fresh oil and filter, air filter,fuel filter,plugs, aux belts, gearbox and diff oil are ok, also changed the water pump/idler/tensioner/tensioner spring,timing belt, cam seals,crank seal, rocker seal, 5 year coolant after a good flush, everything lubed up on rebuild with the future in mind.
next is the braking system, cleaned them up to get rid of everything that was living in and around them before strip down , rebuild and fresh fluid...
- IMG_20190803_110746.jpg (579.89 KiB) Viewed 10728 times
- IMG_20190803_110755.jpg (641.65 KiB) Viewed 10728 times
- IMG_20190803_112057.jpg (647.42 KiB) Viewed 10728 times
- IMG_20190803_112100.jpg (543.93 KiB) Viewed 10728 times
- IMG_20190803_112135.jpg (630.79 KiB) Viewed 10728 times
- IMG_20190803_120506.jpg (614.77 KiB) Viewed 10728 times
- IMG_20190803_120512.jpg (600.13 KiB) Viewed 10728 times
- IMG_20190803_120517.jpg (580.88 KiB) Viewed 10728 times
- IMG_20190803_120521.jpg (669.48 KiB) Viewed 10728 times
- IMG_20190803_120527.jpg (617.18 KiB) Viewed 10728 times
- IMG_20190803_120535.jpg (554.58 KiB) Viewed 10728 times
- IMG_20190803_120541.jpg (590.18 KiB) Viewed 10728 times
- IMG_20190803_120544.jpg (637.73 KiB) Viewed 10728 times
- IMG_20190803_121252.jpg (646.25 KiB) Viewed 10728 times
- IMG_20190803_121257.jpg (644.56 KiB) Viewed 10728 times
- IMG_20190803_121615.jpg (595.31 KiB) Viewed 10728 times
- IMG_20190803_121950.jpg (531.74 KiB) Viewed 10728 times
- IMG_20190803_121955.jpg (444.19 KiB) Viewed 10728 times
- IMG_20190803_121958.jpg (500.62 KiB) Viewed 10728 times
- IMG_20190803_122000.jpg (559.59 KiB) Viewed 10728 times
- IMG_20190803_122003.jpg (579.28 KiB) Viewed 10728 times
- IMG_20190803_122006.jpg (630.52 KiB) Viewed 10728 times
- IMG_20190803_123258.jpg (656.71 KiB) Viewed 10728 times
- IMG_20190803_123303.jpg (677.88 KiB) Viewed 10728 times
- IMG_20190803_123313.jpg (681.89 KiB) Viewed 10728 times
- IMG_20190803_130631.jpg (547.6 KiB) Viewed 10728 times
- IMG_20190803_130636.jpg (552.51 KiB) Viewed 10728 times
- IMG_20190803_131612.jpg (519.85 KiB) Viewed 10728 times
- IMG_20190803_132208.jpg (525.88 KiB) Viewed 10728 times
- IMG_20190803_132211.jpg (551.85 KiB) Viewed 10728 times
- IMG_20190803_132213.jpg (576.72 KiB) Viewed 10728 times
- IMG_20190803_132643.jpg (539.44 KiB) Viewed 10728 times
- IMG_20190803_132649.jpg (586.74 KiB) Viewed 10728 times
- IMG_20190803_133639.jpg (521.4 KiB) Viewed 10728 times
- IMG_20190803_133643.jpg (506.85 KiB) Viewed 10728 times
- IMG_20190803_133648.jpg (569.87 KiB) Viewed 10728 times
- IMG_20190803_133655.jpg (495.07 KiB) Viewed 10728 times
- IMG_20190803_133705.jpg (559.04 KiB) Viewed 10728 times
- IMG_20190803_133711.jpg (536.82 KiB) Viewed 10728 times
- IMG_20190803_135547.jpg (539.81 KiB) Viewed 10728 times
- IMG_20190803_135551.jpg (506.71 KiB) Viewed 10728 times
- IMG_20190803_135555.jpg (547.15 KiB) Viewed 10728 times
- IMG_20190803_141323.jpg (582.15 KiB) Viewed 10728 times
- IMG_20190803_154134.jpg (617.25 KiB) Viewed 10728 times
- IMG_20190803_154142.jpg (646.44 KiB) Viewed 10728 times
- IMG_20190803_154147.jpg (617.1 KiB) Viewed 10728 times
- IMG_20190803_155024.jpg (508.67 KiB) Viewed 10728 times
- IMG_20190803_155038.jpg (604.99 KiB) Viewed 10728 times
- IMG_20190803_155046.jpg (633.04 KiB) Viewed 10728 times
- IMG_20190803_155051.jpg (655.36 KiB) Viewed 10728 times
- IMG_20190803_161819.jpg (607.13 KiB) Viewed 10728 times
- IMG_20190803_161826.jpg (647.18 KiB) Viewed 10728 times
- IMG_20190803_163604.jpg (419.34 KiB) Viewed 10728 times
- IMG_20190804_120630.jpg (560.29 KiB) Viewed 10728 times
- IMG_20190804_120632.jpg (571.81 KiB) Viewed 10728 times
- IMG_20190804_120637.jpg (505.88 KiB) Viewed 10728 times
- IMG_20190804_120641.jpg (453.52 KiB) Viewed 10728 times
- IMG_20190804_132124.jpg (529.1 KiB) Viewed 10728 times
- IMG_20190804_132127.jpg (465.4 KiB) Viewed 10728 times
- IMG_20190804_132131.jpg (411.17 KiB) Viewed 10728 times
- IMG_20190804_132134.jpg (424.97 KiB) Viewed 10728 times
- IMG_20190804_132139.jpg (547.18 KiB) Viewed 10728 times
- IMG_20190804_132144.jpg (376.04 KiB) Viewed 10728 times
- IMG_20190804_132154.jpg (417.81 KiB) Viewed 10728 times
- IMG_20190804_132157.jpg (344.71 KiB) Viewed 10728 times
- IMG_20190804_132208.jpg (550.82 KiB) Viewed 10728 times
- IMG_20190804_132214.jpg (299.56 KiB) Viewed 10728 times
- IMG_20190804_132219.jpg (496.14 KiB) Viewed 10728 times
- IMG_20190804_132223.jpg (297.66 KiB) Viewed 10728 times
- IMG_20190804_132231.jpg (556.22 KiB) Viewed 10728 times
- IMG_20190804_132236.jpg (577.8 KiB) Viewed 10728 times
- IMG_20190804_132239.jpg (418.02 KiB) Viewed 10728 times
- IMG_20190804_132243.jpg (497.23 KiB) Viewed 10728 times
- IMG_20190804_132247.jpg (379.16 KiB) Viewed 10728 times
Braking system all sorted, overhauled, completely stripped,and rebuilt with fresh pads and discs all round...fresh fluid installed,handbrake set..better than factory now...
- IMG_20190805_182553.jpg (647.49 KiB) Viewed 10700 times
- IMG_20190805_182549.jpg (542.19 KiB) Viewed 10700 times
- IMG_20190805_182544.jpg (559.34 KiB) Viewed 10700 times
- IMG_20190805_182538.jpg (556.51 KiB) Viewed 10700 times
- IMG_20190805_182532.jpg (456.31 KiB) Viewed 10700 times
- IMG_20190805_182527.jpg (555.24 KiB) Viewed 10700 times
- IMG_20190805_182523.jpg (610.17 KiB) Viewed 10700 times
- IMG_20190805_170825.jpg (385.34 KiB) Viewed 10700 times
- IMG_20190805_170817.jpg (396.54 KiB) Viewed 10700 times
- IMG_20190805_170810.jpg (387.04 KiB) Viewed 10700 times
Darryl and Vicky has had a trip over to see where i was up to and given me the ok to carry on with the well needed attack to make her lovely again...the plan is that she will be up for grabs when finished ...
They arrived in Vicky's Mk2 California which was in nice condition and after a little test drive mentioned a few little bits needed to make him feel better to use.
So i will do a list of the rest of the attack..
Hmmmmm.
I will be watching for the ÂŁÂŁÂŁÂŁÂŁÂŁ
Stripped down and ready for cleaning and prepping, we even found some more creepers that needed removing....
All the 10mm head bolts snapped and the two studs that hold the under tray in place so, those have all been drilled out again ready for refitting, the drivers side head light as lost its seal and will need replacing at re build, other than that it all came apart as it should be.
- IMG_20190825_195722.jpg (627.9 KiB) Viewed 10412 times
- IMG_20190825_195749.jpg (367.59 KiB) Viewed 10412 times
- IMG_20190825_195801.jpg (358.32 KiB) Viewed 10412 times
- IMG_20190825_195812.jpg (514.62 KiB) Viewed 10412 times
- IMG_20190825_195818.jpg (410.64 KiB) Viewed 10412 times
- IMG_20190825_195848.jpg (486.34 KiB) Viewed 10412 times
- IMG_20190825_195857.jpg (510.85 KiB) Viewed 10412 times
- IMG_20190825_195913.jpg (423.94 KiB) Viewed 10412 times
- IMG_20190825_195918.jpg (438.37 KiB) Viewed 10412 times
- IMG_20190825_195922.jpg (417.66 KiB) Viewed 10412 times
- IMG_20190825_195928.jpg (505.13 KiB) Viewed 10412 times
- IMG_20190825_195935.jpg (548.92 KiB) Viewed 10412 times
- IMG_20190825_195949.jpg (431.08 KiB) Viewed 10412 times
- IMG_20190825_195952.jpg (448.1 KiB) Viewed 10412 times
- IMG_20190825_195956.jpg (443.63 KiB) Viewed 10412 times
- IMG_20190825_200001.jpg (441.19 KiB) Viewed 10412 times
- IMG_20190825_200034.jpg (512.39 KiB) Viewed 10412 times
- IMG_20190825_200038.jpg (426.94 KiB) Viewed 10412 times
- IMG_20190825_200041.jpg (456.39 KiB) Viewed 10412 times
- IMG_20190825_200049.jpg (451.47 KiB) Viewed 10412 times
- IMG_20190825_200055.jpg (504.11 KiB) Viewed 10412 times
- IMG_20190825_200101.jpg (521.79 KiB) Viewed 10412 times
- IMG_20190825_200107.jpg (564.96 KiB) Viewed 10412 times
- IMG_20190825_200113.jpg (506.33 KiB) Viewed 10412 times
- IMG_20190825_200121.jpg (525.44 KiB) Viewed 10412 times
- IMG_20190825_200142.jpg (498.64 KiB) Viewed 10412 times
- IMG_20190825_200153.jpg (553.6 KiB) Viewed 10412 times
- IMG_20190825_200159.jpg (459.01 KiB) Viewed 10412 times
- IMG_20190825_200203.jpg (473.59 KiB) Viewed 10412 times
- IMG_20190825_200213.jpg (457.27 KiB) Viewed 10412 times
- IMG_20190825_200217.jpg (467.57 KiB) Viewed 10412 times
- IMG_20190825_200224.jpg (484.21 KiB) Viewed 10412 times
- IMG_20190825_200301.jpg (451.41 KiB) Viewed 10412 times
- IMG_20190825_200305.jpg (409.55 KiB) Viewed 10412 times
- IMG_20190825_200312.jpg (480.67 KiB) Viewed 10412 times
- IMG_20190825_200335.jpg (484.25 KiB) Viewed 10412 times
- IMG_20190825_200348.jpg (530.05 KiB) Viewed 10412 times
- IMG_20190825_200354.jpg (522.99 KiB) Viewed 10412 times
- IMG_20190825_200358.jpg (539.35 KiB) Viewed 10412 times
- IMG_20190825_200402.jpg (425.27 KiB) Viewed 10412 times
- IMG_20190825_200453.jpg (437.72 KiB) Viewed 10412 times
- IMG_20190825_200456.jpg (394.87 KiB) Viewed 10412 times
- IMG_20190825_200509_BURST001_COVER.jpg (188.35 KiB) Viewed 10412 times
- IMG_20190825_200544.jpg (344.18 KiB) Viewed 10412 times
- IMG_20190825_200548.jpg (391.14 KiB) Viewed 10412 times
- IMG_20190825_200551.jpg (404.13 KiB) Viewed 10412 times
- IMG_20190825_200552.jpg (345.46 KiB) Viewed 10412 times
- IMG_20190825_203053.jpg (401.51 KiB) Viewed 10412 times
- IMG_20190826_134712.jpg (599.2 KiB) Viewed 10412 times
- IMG_20190826_134719.jpg (582.08 KiB) Viewed 10412 times
- IMG_20190826_134724.jpg (542.63 KiB) Viewed 10412 times
- IMG_20190826_134727.jpg (479.12 KiB) Viewed 10412 times
- IMG_20190826_134742.jpg (411.05 KiB) Viewed 10412 times
- IMG_20190826_134747.jpg (407.87 KiB) Viewed 10412 times
- IMG_20190826_134751.jpg (448.44 KiB) Viewed 10412 times
- IMG_20190826_134802.jpg (423.01 KiB) Viewed 10412 times
- IMG_20190826_134807.jpg (432.24 KiB) Viewed 10412 times
- IMG_20190826_134810.jpg (458.88 KiB) Viewed 10412 times
- IMG_20190826_134814.jpg (431.07 KiB) Viewed 10412 times
- IMG_20190826_134822.jpg (573.51 KiB) Viewed 10412 times
- IMG_20190826_134831.jpg (411.92 KiB) Viewed 10412 times
- IMG_20190826_134836.jpg (425.38 KiB) Viewed 10412 times
- IMG_20190826_134844.jpg (437.05 KiB) Viewed 10412 times
- IMG_20190826_134848.jpg (432.13 KiB) Viewed 10412 times
- IMG_20190826_134852.jpg (404.27 KiB) Viewed 10412 times
- IMG_20190826_134904.jpg (506.19 KiB) Viewed 10412 times
- IMG_20190826_134923.jpg (471.02 KiB) Viewed 10412 times
- IMG_20190826_192917.jpg (479.65 KiB) Viewed 10412 times
- IMG_20190826_192921.jpg (380.41 KiB) Viewed 10412 times
Wayne, your â€cleaning/renovation jobs are amazing. Looks to be s very solid car. Good investment of time IMO.
John&Luke wrote:Wayne, your â€cleaning/renovation jobs are amazing. Looks to be s very solid car. Good investment of time IMO.
Thank you, you over humble me sir....i am just doing what i do and hope that others can see if i can do this and get these standards on a drive on axle stands, then everyone can
An inspiring read. Well worth the effort on this car and following with interest.
Nathan
Nathan
10th Anniversary Edition (1999 NB)
Well i have finally managed to catch up with the back log and the clubs 30th/25th rally is out of the way, so i can get back to Darryls Barn find....all the surface rust as been sorted and fresh paint added, left to go off and the underseal protection applied , started to refit panels and will finish that once all the cavity wax is injected into all the correct places first as the seats , trim panel,kick plates and boot trim need to be removed to do some of the box sections also, more on that as i get it done.
In the mean time here are some pics to nosey at...
The reason for the oil containers was because of the wind that day to hold the sheets down, i could not believe how windy it got the day i managed to get to this...
- IMG_20190921_145138.jpg (476.88 KiB) Viewed 10074 times
- IMG_20190921_145144.jpg (490.18 KiB) Viewed 10074 times
- IMG_20190921_145153.jpg (418.33 KiB) Viewed 10074 times
- IMG_20190921_145207.jpg (470.98 KiB) Viewed 10074 times
- IMG_20190921_145212.jpg (533.45 KiB) Viewed 10074 times
- IMG_20190921_145216.jpg (593.65 KiB) Viewed 10074 times
- IMG_20190921_145228.jpg (556.68 KiB) Viewed 10074 times
- IMG_20190921_145237.jpg (671.54 KiB) Viewed 10074 times
- IMG_20190921_145244.jpg (543.43 KiB) Viewed 10074 times
- IMG_20190921_145252.jpg (563.67 KiB) Viewed 10074 times
- IMG_20190921_145344.jpg (517.93 KiB) Viewed 10074 times
- IMG_20190921_145352.jpg (505.89 KiB) Viewed 10074 times
- IMG_20190921_145400.jpg (500.84 KiB) Viewed 10074 times
- IMG_20190921_145408.jpg (546.93 KiB) Viewed 10074 times
- IMG_20190921_145413.jpg (484.53 KiB) Viewed 10074 times
- IMG_20190921_145426.jpg (574.61 KiB) Viewed 10074 times
- IMG_20190921_145434.jpg (510.72 KiB) Viewed 10074 times
- IMG_20190921_145440.jpg (485.75 KiB) Viewed 10074 times
- IMG_20190921_145444.jpg (384.06 KiB) Viewed 10074 times
- IMG_20190921_145454.jpg (553.46 KiB) Viewed 10074 times
- IMG_20190921_145501.jpg (566.33 KiB) Viewed 10074 times
- IMG_20190921_145505.jpg (557.03 KiB) Viewed 10074 times
- IMG_20190921_145510.jpg (460.7 KiB) Viewed 10074 times
- IMG_20190921_145515.jpg (443.45 KiB) Viewed 10074 times
- IMG_20190921_145522.jpg (414.32 KiB) Viewed 10074 times
- IMG_20190921_145528.jpg (554.68 KiB) Viewed 10074 times
- IMG_20190921_145703.jpg (559.1 KiB) Viewed 10074 times
- IMG_20190921_145708.jpg (487.47 KiB) Viewed 10074 times
- IMG_20190921_145745.jpg (556.21 KiB) Viewed 10074 times
- IMG_20190921_145750.jpg (669.52 KiB) Viewed 10074 times
- IMG_20190921_145755.jpg (499.97 KiB) Viewed 10074 times
- IMG_20190921_145759.jpg (464.52 KiB) Viewed 10074 times
- IMG_20190921_145806.jpg (452.5 KiB) Viewed 10074 times
- IMG_20190921_145810.jpg (520.23 KiB) Viewed 10074 times
- IMG_20190921_145814.jpg (478.13 KiB) Viewed 10074 times
- IMG_20190921_145821.jpg (508.34 KiB) Viewed 10074 times
- IMG_20190921_145829.jpg (550.21 KiB) Viewed 10074 times
- IMG_20190921_145832.jpg (580.92 KiB) Viewed 10074 times
- IMG_20190921_145836.jpg (553.91 KiB) Viewed 10074 times
- IMG_20190921_145837.jpg (551.25 KiB) Viewed 10074 times
- IMG_20190921_145838.jpg (613.64 KiB) Viewed 10074 times
- IMG_20190921_145842.jpg (608.73 KiB) Viewed 10074 times
- IMG_20190921_145848.jpg (594.03 KiB) Viewed 10074 times
- IMG_20190921_145905.jpg (548.29 KiB) Viewed 10074 times
- IMG_20190921_150043.jpg (515.48 KiB) Viewed 10074 times
- IMG_20190921_150148.jpg (365.08 KiB) Viewed 10074 times
- IMG_20190921_150159.jpg (517.64 KiB) Viewed 10074 times
- IMG_20190921_150201.jpg (498.1 KiB) Viewed 10074 times
- IMG_20190921_150236.jpg (612.88 KiB) Viewed 10074 times
- IMG_20190921_150244.jpg (469.52 KiB) Viewed 10074 times
- IMG_20190921_150247.jpg (471.73 KiB) Viewed 10074 times
- IMG_20190921_150258.jpg (601.59 KiB) Viewed 10074 times
- IMG_20190921_150305.jpg (395.86 KiB) Viewed 10074 times
- IMG_20190921_150307.jpg (579.23 KiB) Viewed 10074 times
- IMG_20190921_150429.jpg (492.51 KiB) Viewed 10074 times
- IMG_20190921_150433.jpg (439.67 KiB) Viewed 10074 times
- IMG_20190921_160707.jpg (493.58 KiB) Viewed 10074 times
- IMG_20190921_191510.jpg (256.9 KiB) Viewed 10074 times
- IMG_20190921_191514.jpg (309.35 KiB) Viewed 10074 times
- IMG_20190921_191520.jpg (525.75 KiB) Viewed 10074 times
- IMG_20190921_191525.jpg (473.03 KiB) Viewed 10074 times
- IMG_20190921_191529.jpg (565.67 KiB) Viewed 10074 times
- IMG_20190921_191555.jpg (612.62 KiB) Viewed 10074 times
- IMG_20190921_191559.jpg (630.81 KiB) Viewed 10074 times
- IMG_20190921_191604.jpg (500.84 KiB) Viewed 10074 times
- IMG_20190921_191607.jpg (628.23 KiB) Viewed 10074 times
- IMG_20190921_191619.jpg (300.66 KiB) Viewed 10074 times
- IMG_20190921_191624.jpg (439.53 KiB) Viewed 10074 times
- IMG_20190921_191628.jpg (452.72 KiB) Viewed 10074 times
- IMG_20190921_191632.jpg (430.23 KiB) Viewed 10074 times
- IMG_20190921_191635.jpg (514.55 KiB) Viewed 10074 times
- IMG_20190921_191638.jpg (441.85 KiB) Viewed 10074 times
- IMG_20190921_191644.jpg (436.58 KiB) Viewed 10074 times
- IMG_20190921_191647.jpg (455.53 KiB) Viewed 10074 times
- IMG_20190921_191658.jpg (521.7 KiB) Viewed 10074 times
And this was my face scrub and shampoo after doing it.....
- IMG_20190921_213827.jpg (375.98 KiB) Viewed 10074 times
- IMG_20190921_213703.jpg (296.57 KiB) Viewed 10074 times
- IMG_20190922_110823.jpg (641.51 KiB) Viewed 10074 times
Users browsing this forum: Google [Bot] and 16 guests
