1995 G-Limited ***RESTORATION***Rebuild
John&Luke
Re: 1995 G-Limited ***RESTORATION***Rebuild
Postby John&Luke » Sun Nov 29, 2020 10:40 pm
Great work :handgestures-thumbup: :handgestures-thumbup: :handgestures-thumbup:
Postby blackyb » Sun Nov 29, 2020 11:34 pm
She will as if she has just rolled off the production line by the time your done.
Lumphammer
Postby Lumphammer » Sat Dec 05, 2020 9:26 pm
Put the diff back in with the PPF as one unit, got everything torqued etc
Started on the engine, took the head off to see what the state of it was. A load of cr*p from plug number 3 fell in, hoovered it out
Looking at the state of the head gasket I'd lost confidence in how healthy it was. I knew it had had a tough previous life and decided to take it to bits fully
Really not that great, main bearings scored pretty bad
Crank scoring was less, i would guess 1-2 thou. I can linish that out hopefully
Got the measuring sticks out
The good news is that the ovality and taper is within spec and it hasn't been rebored previously
But this sh*te concerns me
My friend feels it might hone out but if not it'll be a second hand VVT engine and rebuild the bottom end of that with the 9:1 pistons from this - which are fortunately in very good condition
Lumphammer
Postby Lumphammer » Wed Dec 09, 2020 4:52 pm
Unfortunately the marking is corrosion, probably from being sat so long outside, it's deep enough that the block would need reboring rather than just honing :sad: I could put the money into this block but when you add together the cost of the parts just to get it within spec again it's just not worth it. Might as well get another secondhand engine.
The engine i've bought is a 2002 VVT 1.8 with 64,000 miles on it from a car that's done 3-5k miles every year. Ive checked the MOT history so I'm hopefull that its a good one :think:
In the mean time I've been making a modification for the fuel rail. The VVT engine uses a returnless system with the pressure regulator in the tank whereas the MK1 has pump in the tank and the FPR on the fuel rail before it returns to the tank.
I have a spare VVT head I bought from some random bloke on the internet for throwaway price at the start of summer, so this is the MK1 head (left) next to a VVT head.
You can't simply swap over the fuel rails because the holes don't line up and I think the MK1 FPR gubbins might foul on the VVT's bigger "square top" manifold.
There's a "pulse dampener" on the VVT fuel rail which has the same fitment pattern as the MK1 FPR but there isn't enough space to get the MK1 FPR in between the head and the rail - so you can't simply swap the FPR with the pulse dampener
I've found various methods on the internet of how people do this on "VVT swaps" and the common thing appears to be to use a MK2 1.8 fuel rail with the MK1 FPR placed upside down on the end of the rail - I can't think of anything wrong with this but I don't have a MK2 1.8 fuel rail, there wasn't any on eBay and I'm fed up of buying stuff so decided to make something.
My normal car is a MK2.5 VVT, there's not a lot of space up at the front of the fuel rail at all but there's a good amount at he back, especially as I won't be using any of the EGR clutter
After much head scratching and messing about I've come up with this idea - Make a fitting to go on the end of the VVT fuel rail where the pulse dampener would sit, run a pipe around to the back and stick the MK1 regulator there and make it rigid enough that it doesn't vibrate / bend etc
The alu fittings lockate in the rectangular holes where the plastic cable tray clips and hold the 2mm wall, 12mm OD hydraulic stainless tube which carries the fuel but also acts as a structural support for the MK1 FPR
Decent clearance on the injectors, manifold is close but I think will fit OK
MK1 FPR in an upright position at the end of the rail, the vacuum reference points towards the manifold which is nice
All the parts are stainless and will be brased together when the replacement engine arrives. I don't want to chance it now in case there's something I forgot about. Need to get a couple of 8mm ID x 2mm thick viton o-rings for the seals.
I'll be chopping off the existing "b**tard clip" on the VVT fuel rail and brasing on a MK1 style bead rolled fitting too
Lumphammer
Postby Lumphammer » Wed Dec 09, 2020 8:53 pm
Had a go at brasing one of the parts, haven't done any for a while. Came out good - 55% silver rod
Will pressure test it when it's all together
Postby Mazda Mender » Wed Dec 09, 2020 10:51 pm
:text-goodpost: :handgestures-thumbup: :coffee:
Postby blackyb » Thu Dec 10, 2020 9:47 am
This is taking mending to a whole new level.
Excellent write up and great to follow.
GlennyGills
Postby GlennyGills » Thu Dec 10, 2020 10:40 am
Very enjoyable build
Lumphammer
Postby Lumphammer » Sun Dec 27, 2020 7:35 pm
Got held up on parts for the engine unfortunately so did a bit today on the brakes
These are MK2.5 sport brakes, I bought them secondhand "condition unknown" for something like £80, i can't remember exactly. They freed up alright and were probably useable as-is but I shot blasted them and they've had 4 coats of brake caliper paint - two black and two silver. I used different colours because you can more easilly see bits you've missed.
The slider pins are all the originals, they had virtually no corrosion on the sliding parts but were a bit worn so they were shot blasted, polished and sent of with the rest of the plating bits many months ago.
I used a caliper rebuild kit from Frentec (eBay) which i think is very complete and good in quality, the cost was around £65.
I think all in they owe me about £150 plus a bit of effort.
I've not rebuilt a caliper fully before but I would highly recommend it to anyone that needs to, it's very easy. There is a video on YouTube from bofi racing which is very helpful.
Lumphammer
Postby Lumphammer » Wed Dec 30, 2020 7:00 pm
Took the starter motor to bits because... ?
Thought i'd put a few pictures up because it's quite interesting inside. It has a planetary reduction gearbox which I didn't expect. Also didn't expect the ring gear to be glass reinforced plastic - but it works and makes much more sense as to why the later MK2/2.5 starter is much smaller than the MK1 starter which is direct drive
The throwout gear and pinion that engages with the flywheel has a one way bearing built into it. They're quite interesting because you don't come across them much. I assume it's there to allow the starter to freewheel against the engine rotation while the pinion retracts. If anyone want to take one apart the only difficult bit is getting the c-clip to pop back into the retaining collar when reassembling (lower left)
I cleaned everything up and reassembled it with lithium based moly grease, wasn't sure how tolerant the plastic was of normal grease.
There was tons of meat left on the bushes so painted it up and put back together
Looks a bit better than the usual 15 year old condition :-D
Postby Mazda Mender » Thu Dec 31, 2020 9:56 am
GlennyGills
Postby GlennyGills » Sat Jan 02, 2021 9:06 pm
Excellent work
Lumphammer
Postby Lumphammer » Mon Jan 04, 2021 7:58 pm
Took the VVT engine oil pump to bits, my motivation for doing this was to get an indication of the internal health of the engine without doing a bottom end strip down - which I don't want to do right now.
The gears are in exceptional condition which confirms that this is a low miles engine that hasn't been messed with previously :-D
The outside casing was really manky, I got a bit OCD and decided to make it look nicer. Spent a while masking off all the precision surfaces with tape and rubber sheet and media blasted it
Cleaned, painted in VHT silver and baked in the oven at 220C
Cleaned the hell out of it until I was 110% it was utterly clean
Reassembling the parts. Replaced the split pin on the pressure bypass but otherwise the parts went in as is
All the innards back in with assembly lubricant, bar the back plate
Torqued down and ready to go back on
Lumphammer
Postby Lumphammer » Mon Jan 04, 2021 8:16 pm
Had to take the sump and main bearing support plate off to get the oil pump off so cleaned them up too
Got the sump totally cleaned out of all the old oil
Baffle, cleaned and reattached with loctite blue (243) on the threads
Retapped the holes in the block, there gets loads of old silicone and rust in there after years of use
I used this stuff I had leftover from doing the bathroom years ago. This stuff is amazing, just cheapo screwfix stuff but it attacks silicone and you can scrape it off with a stick or wire brush
MBSP - like most of the parts I cleaned them with petrol and wiped clean. Siliconed (loctite 5980) and back on. Replaced gasket on the oil pickup
Silicone on the sump, trying to be neat. Think i used a touch too much but should be fine
Sump back on, torqued in two stages. Screws were replated zinc / yellow a while ago.
Onto the top of the engine, all oil seals replaced
Lumphammer
Postby Lumphammer » Mon Jan 04, 2021 8:32 pm
Finished the fuel rail. I turned the standoffs into saddles so I could remove the rail more easily by undoing the two screws on each, I did the bend at the front in one piece because having a join looked c**p.
Pressure test on the junk head at 75PSI, used refrigeration leak detector spray. Its just ultra foamy washing up liquid in a can.
I used filler to smooth out the joins and then painted it
I think in the fullness of time I'm going to re-make it - first thing is that when brasing i must have c**ked up my setup so the regulator sits at a jaunty angle, that bugs me. Also the general cumbersome layout I dont like and the filler which I thought would smooth it all together, looks rubbish! :-D
I've been using this stuff, it's from Frosts and is actually quite good - with caveats. I think it's mostly either hydrochloric or phosphoric acid, it eats zinc so beware. It says it just needs agitation with a brush but I found a brass toothbrush is needed on very scabby parts. Anyway, it's quite good and with electical tape you can effectively mask of bits you want left alone. If anyone has tried to clean an inlet manifold with petrol / degreasers you'll know how futile it is but this stuff just eats it. These are unpainted but are ready for paint.
Done the VVT housing actuator in this way
And the cam cover has come out nice. Both painted in VHT silver and baked in the oven
Apart from that, painted a few bits and my plan is to get the engine into the car in the near future
