A bit more time yesterday evening (lucky me!), the plan was to strip any final bits from the interior and then remove all the remaining dodgy seam sealer in preparation for the raptor respray.
I worked my way round the remainder of the driver's side and it was pretty uneventful, I'd already dealt with a crusty bit in the driver's footwell (as can be seen in an earlier post) so that was fine.
I was expecting the passengers side to be more of the same, there was some staining in the passengers footwell that looked like water had been sat near the ECU for a while (seems a common issue, anyone care to explain?), but having gone over it with a wire wheel it didn't uncover any nasties, result!
My luck ran out as I worked my way to the rear bulkhead of the passengers side, right in the last corner (sod's law!) I found this:
- IMG_20200813_195942.jpg (775.31 KiB) Viewed 9100 times
Nothing for it but to cut the crust out and weld in some new metal. It's a tricky bit of the body as you have three skins all meeting at this point, of course it's always the multi-skinned parts that rust!
- IMG_20200813_201440.jpg (722.08 KiB) Viewed 9100 times
- IMG_20200813_204737.jpg (532.72 KiB) Viewed 9100 times
By this point it was pretty late so I made a measurement for a replacement piece and marked up some steel. This will have to wait as I'm off next week for a campervan holiday to the Peak District!
Hopefully that'll be the last of the rust... Pretty sure I've said that before!
