Re: Another NA ***RESTORATION***
Posted: Tue May 12, 2020 6:34 pm
That was a very productive day Nate, nice work!
The ultimate MX5/Roadster resource for fellow owners
https://www.mazdamenders.net/forum/
https://www.mazdamenders.net/forum/viewtopic.php?f=35&t=7596
John&Luke wrote::text-coolphotos:
Are you intending to joint the new rear panel to the original in a straight line at the top of the new panel?
Also I remember you will get some movement/ Walpage when you weld the new panel.
Natehd9 wrote:John&Luke wrote::text-coolphotos:
Sorry J&L, which panel do you mean? The sill to the b pillar? That was going to be the plan, although if you've got some pearls of wisdom please share!
I'm planning on stitch welding but working a small (inch or so) weld one end then jumping to the other end and slowly working towards the middle, will likely give the welds a blast with the air gun every few minutes too.
graymattor wrote::clap:
Another great thread, you guys have some great skills, great tools and big balls lol..
Mine will be a lot simpler and scrambling on the floor, I do love your rotisserie simply and effective, but I doubt I'll be taking the engine out when I do mine, I could do with doing but that adds further complications
Keep up the great work, descriptive posts and photos, helps others (me) a lot
Natehd9 wrote:
John&Luke wrote:Yes agree, inner arches almost certainly rot along with the outer edge as I guess the corrosion sets itself up between the two panels.
John&Luke wrote:This will stiffen up the original panel and provide an overlap surface to weld. I joggle the original panel so the open edge of the joint is facing down presenting less chance of water or crud sitting in there. .
