2002 Arizona Rebuild
- Lumphammer
This is my 2002 Mk2.5 "Arizona" 1.8 VVT. The car is a fairly standard 1.8 Mk2.5, it's got Gaz Gold Pro suspension, roll bar and usual SE factory fitted stuff
I've owned it for about 14 years and it's a the car I drive every day. I've done a lot of servicing and maintenance on it over the years and it's the first car I ever did any work on. A few years ago I re-did most of the underside because several of the wishbones had rotten through.
Unfortunately this time round it needs a lot more. Both rear arches are totally shot, there's no inner wing anymore
Near side:
Off side is the worst of the two but they're both kaput:
Both rear lowers are gone, there's a hole in the near side and i reckon i could poke one in the other pretty easy:
Bubbling comes and goes along both sills, so they're shot too
Engine bay suggests the chassis rails are gone or near to gone:
Remarkably both sill end plates look alright, so i haven't bought any of them (yet..) but i've bought some genuine Mazda sills and aftermarket rear arch repair panels. Not massively happy with the repair panels biggest objection is the crease and fold where the panels tuck under the sill pieces
Learned a few things from the blue car - mostly that I'm never painting a car with rattle cans again! Spent a bit of time making a nice air setup
I got this big compressor for Ā£50 second hand, it's 14cfm with a 150 litre tank. Needed a new head gasket and a new soft start / pressure cutout switch but it works great now
And a small 8cfm compressor during the first lock down for Ā£20 that just needed a new rubber washer cutting for the blow off valve
I read that water can be a big problem with compressed air in a garage so I made a water separator out of 15mm and 22mm copper
The two lower legs are drained with these two ball valves
The big compressor is noisy as hell so put in an external hookup for it so it can run outside. Used a PCL Euro XF connector to get good flow and put in an external socket on a 16A radial back to the CU
Both compressors feed into the water trap so I can use the big one, small one or both if I want to do something like shot blasting.
Most of the time i'll be using the smaller compressor inside. At the angry end is a filter regulator then another filter and it splits off with one part going to an oiler for tools and another for clean dry air for paint
I'll need to fabricate several pieces including an inner arch as there's nothing left where it should be, so got some basic benders and a shrinker stretcher
I've had a go with the shrinker stretcher and i think it'll do a good job at making a new inner wing
Also got a couple of air tools - punch / flange setter for the large number of plug welds i'll need to do and a nibbler for trimming panels etc. Then just loads of cheap mole grips and a basic pannel beaters hammer set
Was going to start this weekend but I'm laid up with a cold. First thing will be to get it up on axle stands on the drive, remove bumpers / front wings and pressure wash everything to within an inch of it's life. Don't want to be bathed in road dirt dust when wire mopping like last time
Then get it inside and see how far down the rabbit hole i'll end up going. Appreciate there's no economic point in doing this but I like this car so it's getting done properly regardless of how much cost and misery it entails
Near side:
Re: 2002 Arizona Rebuild
- graymattor
- Regular
You are a sucker for punishment Lumphammer lol!!
14 years of ownership, impressive, and a decent spec as well, judging by the results of the last one, this one can only be better..
Really looking forward to seeing your updates.
PS i would love to see more info on your water loop for the compressor, and i would love to pipe mine in copper around the garage too so i dont have pipe running all over the place.. I too have a 150l 14CFM compressor, i am hoping its man enough for the equipment i have and paint spraying, its an old beast that could do with a service but works well, (i was considering an air receiver tank (or a tank from another compressore that was beyond repair).. I think a shrinker/stretcher and bender is on my list to get next! i really want to start mine but im SOOOOO hesitant with not doing anything like this before!! mine would never be to the detail and depth of your builds, i really just want to do it right so the Mrs can use it next year
Keep the updates coming
graymattor wrote:You are a sucker for punishment Lumphammer lol!!
Then make a start and do it bud...we are here to kick your ar*e if your stuck or slacking.
- graymattor
- Regular
Mazda Mender wrote:graymattor wrote:You are a sucker for punishment Lumphammer lol!!
Thanks, i need it!! i am 'hoping' to spend the Christmas break working on the Mrs's car, i've just finished the bathroom renovation so i am going to have a bit of time off the house while i work on some garage projects (i hope)
Well we are here if needed...it's making that initial start...once started there is no turning back to finish , we can share our knowledge to help and brush the UN confidence away...
If you personally need me , you can get me easy enough.
Cant wait for some new reading material for 2022.
- Lumphammer
It's just a simple water separator, the increase to 22mm drops the flow which helps separate water suspended in the air and the copper has a big surface area so the warm water vapour condenses on the walls and dribbles down. The two ball valves get opened periodically to release any condensed water. I copied the design from YouTube videos if you search for DIY water separator although it's a bit smaller than most because I didn't have much space to play with - hopefully it works...
Had a good weekend taking stuff off and pressure washing the filth off - it was cold!!
Not found great stuff, many holes, sills are worse than I'd expected
Pretty bad. The inboard sill piece looks bad and the front girder bit is gone.. poof..
This is what it's supposed to look like when it's a bit rusty but still exists (still from a YouTube video)
Rear inner arches i thought would need a bit of farbication but nope, most of them is gone poof too!
This is how the rear inner arch is supposed to be formed (still again from YouTube video). Might be tricky to fabricate.
Front of the rear arches isn't as bad but the rot is still there. Probable need to get some new sill end plates
Battery tray is a bit furry but will be fairly straightforward to remake
First thing to work out is how to make a jig to fabricate a new inner arch as everything is rotten and I need a lot of access
And then get this thing less rotten. Probably end up putting it on the rotisserie again, it's got to the point where if I don't fully strip it then it won't last another 5 years
I just see standard issues , cut out, treat, replace ,protect...
- Lumphammer
Found that the battery tray rust was a bit worse than expected
Marked out the rust bit on the outside
Made a template and cut from 1.0mm steel
Put the return bend in first to give it a bit more rigidity and because it wouldnt have worked any other way then used an offcut of hardwood ply to make a crude bashing jig, clamped it down to stop warping and hit with a square faced hammer
Part came out pretty well
Tacked it into place on the car, was able to build to what was left of the metal & rust tray
With that tacked in I've got something to build to so I could remove the rest of the tray. Drilled out the spot welds holding the back part of the tray and then separate part of the lower rear arch
Load of rusty bits, but it's feasible to work with now
Made several templates for the tricky parts
This one was a sod. Used the shrinker stretcher quite a bit, it's pretty easy to work with
This is the patchwork quilt of of the rebuilt tray. It's alright, not mega pretty but it's solid. Will dress it back a bit but not overly fussed - it's a battery tray
Fits in well. Got the tray and the removed rear panel held together with clamps at the moment
Going to weld the inside cut line from hole provided by the removed panel. The outside edges will be plug welded from the outside of the car because it's easier
I've no idea if this is the right way to do it, couldn't see any other examples on the internet.
Got a bit more work to do on it, the removed panel has some rust that needs to be cut out but and fixed but that's fairly straightforward as it's all on one plane.
- Lumphammer
Finished the panel thing, the top bit was a bit fiddly as it's got a step and a funny curve
fits well. Need to drill the plug weld holes and weld it in but will hold off a few days in the hope i can give both parts a shot blasting before painting
This bit on the near side looks sketchy af
It's buggered. Shouldn't be too bad to replace because both parts are flat and there's a convienient cut point around the spare wheel tray
Bet there's other rusty stuff under that tho. Probably do the off side too, can't imagine it's far behind. Rear chassis rails look OK tho.
You might be better getting some chemical on the underneath on and around the tie down hoop.
- Lumphammer
Going to try blasting and painting it when the backs off, i imagine it'll be horrifically messy
- Lumphammer
It's not that bad, lots of the lips will need replacing, the jack storage tray lip is gone
Rails are good at least
Lot easier to sort with that back panel off.
Return to āMembers Mx-5/ Roadstersā
