Fleas sh*tter project
Postby flea » Wed Sep 19, 2012 7:01 pm
Can i have a locked thread for my project car please. Captain & I were talking about it today & it would be better if it did not go off topic. Ive already took loads of pictures :wink:
Re: Fleas shitter project
Postby flea » Wed Sep 19, 2012 7:17 pm
when i got home the car was filthy & the roof was green
Then i had to wash it
Re: Fleas sh*tter project
Postby flea » Wed Sep 26, 2012 7:35 pm
Right her we go this is what the bodywork is like before i start
s
Postby flea » Wed Sep 26, 2012 7:44 pm
Then the bloke next door said i could use his garage for a few weeks to put the flea so i would have more room to work. Happy days :-)
Postby flea » Wed Sep 26, 2012 7:53 pm
Inside :oops:
Postby flea » Wed Sep 26, 2012 9:42 pm
Under the bonnet........yuk
Postby flea » Wed Sep 26, 2012 9:45 pm
Quick clean for now
Postby flea » Wed Sep 26, 2012 10:12 pm
Undercarriage
Remove some bits (that's a surprise every clip & bolt was in place) nothing broke or snapped.
Postby flea » Wed Sep 26, 2012 10:18 pm
Yuk
Postby flea » Wed Sep 26, 2012 10:21 pm
Postby flea » Wed Sep 26, 2012 10:24 pm
That's not an oil leak on the under tray just been a bit mad with the penetrating spray
Postby flea » Thu Sep 27, 2012 1:42 pm
Although the rear sills didn't look to bad i thought i would expose them anyhow as there was slight pitting. The off side one was original but the near side one had been replaced well at least they tried as there was filler at the back. It looked as though the car had been slightly grazed on the near side against something some time age. You can see by the graze below the door jam & also where they tried to touch up just above the rear quarter. Any how there off & you can see what i found. Not to bad as the flea was a lot worse. Off side is very solid & near side is a little worse. Im going to treat it all first inside & out to see what im left with.
I know the cutting out is a bit messy at the moment but i'll tidy that up when the new sills arrive. Just wanted the chemicals to do there thing.
Postby flea » Fri Sep 28, 2012 2:04 pm
Worked last night. Been up a while now & got my head on straight. Mmmmm i think i'll get them calipers off & give them a strip down & clean up. I'm gonna throw the discs away as they are a bit crazed & new ones are not to expensive.
I was going to have a go at the welding the quarter's myself but after talking to a mate of mine he said he would spot weld the new ones for me when its ready. May still have a go myself as i have the gear but only used to welding thick old beams & stuff. I'll have a think on that one as it may be a good learning curve :eek: Maybe play around on some thinner sheet first :think:
Postby flea » Fri Sep 28, 2012 9:42 pm
Well i think i done quite well this afternoon. Calipers & discs off. Not cleaned them up yet due to i was in a stripping down mood once i got started.
Postby flea » Fri Sep 28, 2012 9:44 pm
Like said i was in the mood so i ended up with another pile but a little bit bigger :whistle:
