Fleas sh*tter project
Re: Fleas sh*tter project
Postby flea » Tue Nov 13, 2012 4:05 pm
After cleaning off & applying more Kurust & cleaning off again it was time to start applying some paint on the bits.
Postby flea » Wed Nov 14, 2012 3:17 pm
Given me bits a few more coats & the sub frames are just about ready for painting now. Pictures to follow
Postby flea » Thu Nov 15, 2012 5:54 pm
After more rubbing down & a further few coats the wishbones are just about finished. We happy with them now.
Postby flea » Thu Nov 15, 2012 6:08 pm
I was not happy with the rear sub frame so re wire brushed & hammered off the surface rust & have given it another coat of kurust So coats of paint will now have to wait until its thoroughly dried out so i can sand it again. Still removed the rear springs & started to clean all the crap off them.
Postby flea » Sat Nov 17, 2012 6:51 pm
Rear sub frame almost done
Front too
Now i have started to get the crap off the hubs & stuff.
I know there's a load of crud around the flexi break pipes but they wont be staying
Postby flea » Tue Nov 20, 2012 9:50 pm
I know it don't look a lot but a lot of tapping with the chipping hammer & wire brushing has been going on today on the hubs & bits. Now given it another coat of Kurust. Remembering to give the rubbers a smearing of Valvoline so as not to damage them.
Also thought id clean up the fuel filter bracket while i was at it too
Still needs a few more coats
Postby flea » Thu Nov 22, 2012 7:07 pm
Finished cleaning all the crap off the hubs & started to paint.
Also cleaned all the crap off the calipers before stripping them down.
Postby flea » Fri Nov 30, 2012 9:55 pm
Refurnished & stove enameled my calipers.
Postby flea » Sat Dec 01, 2012 11:12 pm
Got my rims. Thanks to Terry from modsters :handgestures-thumbup:
Also managed to get some old chrome hub caps that were still in the tissue paper :-D so they are brand new.
You got to imagine the rims finished in cream
Postby flea » Sun Dec 02, 2012 1:40 pm
Started to fit all the new bushes :handgestures-thumbup:
Postby flea » Wed Dec 05, 2012 3:03 pm
Bushes done :handgestures-thumbup:
Postby flea » Mon Dec 10, 2012 8:02 pm
Done my first bit of welding. Cut a section of inner quarter & welded a section back. Its a bit sloppy but with a bit of practice i hope to get a bit better at it.
Outer skin is about ready to go on.
Postby flea » Mon Dec 17, 2012 7:12 pm
Got home a little bit early & got the outer skin on.
Not bad for first time i don't think. Needs a bit of face filling but i'm happy & no more rust :-D
Postby flea » Sun Dec 23, 2012 3:36 pm
Considering the age of the car i would have expected the near side to be a lot worse than i have found. Cut out all the rust & this is what i'm left with :dance: so i am very pleased. You can even see the original primer on the inside so she's not to bad.
Postby flea » Sun Dec 23, 2012 4:12 pm
couple of coats of converter to make sure it gets any bits i've missed.
photo (2).jpg (36.86 KiB) Viewed 4711 times
Then a few coats of weldable primer
photo (3).jpg (47.58 KiB) Viewed 4711 times
