Suspension swap - other recommended parts to renew
Wardy
Postby Wardy » Wed Jul 04, 2018 5:01 pm
I'm replacing my ageing Bilstein setup with a new Gaz fixed height coilover setup (yes I did ponder this for some time, but they were well priced and I could justify the same cost again on Meisters!)
What else should I realistically replace while I'm doing this? I have some new bumpstops to go on, but are there other bolts etc that I should renew?
I'm also thinking about bushes, but don't really want to shell out £300-odd on new bushes! (using the IL kit from MX5Parts as an example).
Cheers,
Steve.
Re: Suspension swap - other recommended parts to renew
Postby Mazda Mender » Sat Jul 07, 2018 9:45 am
Are they not complete units ready to fit?
Wardy
Postby Wardy » Sun Jul 08, 2018 12:22 am
They are, but I'm thinking of associated parts while I'm swapping the units really.
Postby Mazda Mender » Tue Jul 10, 2018 6:25 am
Remind me MK 1 or 2?
Wardy
Postby Wardy » Thu Jul 12, 2018 1:14 pm
Mk1, '93 1.6 S-Special.
Postby Mazda Mender » Thu Jul 12, 2018 10:14 pm
Then nothing really unless items are worn ? you might need two new split pins when you split the uprights at the front....check your drop links, and front dust boots.....
Grease,penetrating oil .
Postby Mazda Mender » Thu Jul 12, 2018 10:33 pm
