Oil leak ?
Oil leak ?
Sometime ago I smelt buring oil and replaced the Cam sensor (1.8) and things were better. Now however after replacing a Rocker cover, minor oil leak, it seems as if there is another problem. There is wet patch behind the crank pulley. Is there such a thing as "Radweld" for oil systems, or am I doomed to learn how to extract the engine and replace leaking seals? Crank pulley seal??
- ps Picture rotated 90deg clockwise.
- OilLeak.JPG (151.43 KiB) Viewed 5715 times
Re: Oil leak ?
Easy enough to replace and solve the problem.
Re: Oil leak ?
mazda-mender wrote:Easy enough to replace and solve the problem.
Excuse the ignorance, but what is easy enough to replace.
Re: Oil leak ?
Crank oil seal.
- roadster1980
Re: Oil leak ?
A mate did mine in 1hr start to finish, fitting the seal takes a couple of minutes
- binarypunk
Re: Oil leak ?
A bit more detail may help? As I understand it, you need to take off the crank pulleys (so, timing belt off?) then cut out the old seal and drift in the new, then back together. I assume you need to drain the oil, but you might get away with a big rag and working quick...
Re: Oil leak ?
Yeah pulley and belt off to do this.
Re: Oil leak ?
If the timing belt comes off, may as well put on a new one. Anything else whilst in the area? Water pump? Always worried about doing the timing belt, small mistake big consequences.
Is there a write up ?
Re: Oil leak ?
I think flea wanted to do one for the Mk 1? but either way there will be for all versions mk 1 ,snc and LNG, mk 2 and Mk 2.5 vvt.
