Underseal Berkshire way
GlennyGills
Postby GlennyGills » Thu Oct 16, 2014 6:32 pm
Hi, I am looking for a trusted company to underseal my MK1. I am looking for something local to Reading if possible. Any suggestions?
Re: Underseal Berkshire way
Postby Mazda Mender » Thu Oct 16, 2014 9:34 pm
To far for me buddy.
Shadgrind
Postby Shadgrind » Sun Oct 19, 2014 12:19 pm
Me too, though I do also need to get surface rust off my chassis rails first though. Hope it is just chassis rust, eeek.
Mk2 Twilight Blue. 1.8
Low fuel Autolink light.
Style bar.
Postby Lazza » Sun Oct 19, 2014 10:29 pm
I'm local but no help. I'm planning to take mine down to Gareth (MX5 Restorer) at some point so he can do mine.
Shadgrind
Postby Shadgrind » Mon Oct 20, 2014 11:32 am
I'm in the process of getting a quote from DrMx5 down in Southampton.
Style bar.
Shadgrind
Postby Shadgrind » Mon Oct 20, 2014 11:36 am
Got a reply actually. He says £170 and half a days work if it has not been driven in the wet recently.
Going for that I think
Style bar.
GlennyGills
Postby GlennyGills » Mon Oct 20, 2014 12:54 pm
That sounds good, I think I will be on the phone shortly.
Postby Lazza » Mon Oct 20, 2014 2:35 pm
Does that include all the cavities i.e. inside the sills and chassis rails?
Shadgrind
Postby Shadgrind » Tue Oct 21, 2014 8:54 am
I hope it does but as long as it is inside arches and underneath, then it's not too bad. I will ask, trying to book in now.
Style bar.
Postby Lazza » Tue Oct 21, 2014 12:07 pm
I'm only getting mine done to protect the most vulnerable areas which on a Mk2.5 is the sills and front chassis rails. Anything else is pretty much cosmetic.
Postby Mazda Mender » Tue Oct 21, 2014 12:22 pm
Sills, arches, front rails in and out, underneath,under rail box sections inside,all box sections,front inner wing/back and bottom where it meets the sill (drainage point from skuttle and is always full of crud rotting away ) subframes.bones etc etc, do it right first time ,job done.
Postby Lazza » Tue Oct 21, 2014 1:19 pm
When I say that I'm only getting mine done to protect the most vulnerable areas (sills and front chassis rails), I don't mean those are the only areas I'd get done, just that those are the main focus. If they aren't going to be done properly I'm not interested and I'll go somewhere else. The rest of it is fairly simple and the same as any MX5.
dikki10
Postby dikki10 » Wed May 06, 2015 6:00 pm
Actually I want to look at doing this myself but was planning to get underneath to start wire brushing off all the surface crud first. However to do a first pass clean up best as possible before going under with the brush what's best to do a general clean of loose crap and dirt so I can see minor details like where frame stops and control arms start instead of something that looks like a dirt pile :) - jetwash ? bit wary of it as I've got one of the side diff seals leaking slightly ( small leak its been diagnosed as ) so want to get off the diff oil that's sprayed underneath and get the dirt and crap off everything but spraying high pressure water under a Eunos seems a bit ... wrong. I am guessing steam would be better but forecourts don't tend to have them - What have the rest of you guys done when you first get your rides to start making them dinner plate plush ?
Postby flea » Wed May 06, 2015 6:30 pm
Elbow grease, mechanical wire brush & needle gun is what I've used. Then treat any sign of rust with converter then prime all bear areas before putting anything else on
Yolo
Postby Yolo » Wed May 06, 2015 8:00 pm
I am going to have a go at doing my own. Have the dintrol kit I just need to get on with it.... Wire brush and elbow grease....
