waterpump/cambelt etc replacement howto?
sandmonster
Postby sandmonster » Mon Jan 04, 2016 1:23 pm
Is there a comprehensive howto for this on here - have had a little search but not come across it?
I'm gearing up to replace my thermostat housing (leaky t-piece) and will check/replace everything else that I can while I'm 'in there'. Could do with a comprehensive list of jobs/bits and any hints/tips that aren't likely to be in the Haynes book.
Also recommendations on the bits - I note MX5parts do a 'ultimate' kit http://www.mx5parts.co.uk/camshaft-timi ... -3328.html but it has a pattern waterpump?
Also my 1992 Eunos wont be 'early crank' in the options for that kit will it - how do I tell?
:text-thankyouyellow: in advance. :handgestures-thumbup:
Mxmurray
Re: waterpump/cambelt etc replacement howto?
Postby Mxmurray » Mon Jan 04, 2016 2:29 pm
The Short nose Crank has 4 "slots" in the pulley whereas the long nose crankshaft has 8 "slots".
I think there is only about a ÂŁ20 difference in water pumps between aftermarket and genuine so that's a choice for you.
I bought the kit from mx5 parts but asked for a genuine cam cover gasket as the pattern ones are not the same quality.
Postby Mazda Mender » Mon Jan 04, 2016 4:09 pm
I'll answer this later :wink:
sandmonster
Postby sandmonster » Sun Jan 10, 2016 11:06 am
This looks like a place to start - seems to skip some bits, but fairly comprehensive... https://www.youtube.com/watch?v=YwaHeAPd14A
This one does the seals too: https://www.youtube.com/watch?v=gtZEUnnZYyI
Another one with some more bits: https://www.youtube.com/watch?v=2hLuUi32UgY
And this one lots of good tips - love the guy's hat - I think Wayne should have a similar one ;) - https://www.youtube.com/watch?v=oovptq0q7vc
Postby Mazda Mender » Sun Jan 10, 2016 8:22 pm
When are you thinking of doing it as i will be doing a pump and belt next weekend which i will be using for a pump and belt how to, re-photo's and write up, speedy is doing one at the minute with a SNC to, if you can hang on we will be doing some, but as for your parts use Autolinkmx5 and our discout code.
sandmonster
Postby sandmonster » Tue Jan 12, 2016 1:44 pm
Hi Wayne,
Not doing it for a few weeks - need some dry-ish weather forecast LOL :lol:
Just doing some background research and building up a list of stuff to order.
So far I have:
  1. Timing belt kit (Belt, tensioner, idler & spring)
  2. Water pump with gaskets
  3. Thermostat housing (got 2nd hand one - pipe is a little rusty, but do I buy new, or do the brass t-piece mod?)
  4. Thermostat housing gasket
  5. Thermostat with gasket
  6. Rocker cover gasket
  7. Antifreeze
  8. maybe cam seals
  9. maybe crank seal
  10. maybe hoses?
  11. CAS o-ring
  12. alternator belt - just changed
  13. power steering belt - just changed
Postby Mazda Mender » Tue Jan 12, 2016 4:21 pm
CAS O'ring, aux belts, check your rear hoses and the rest looking at the engine bay.
sandmonster
Postby sandmonster » Mon Jan 18, 2016 2:06 pm
+ waterpump inlet pipe o-ring
+ any special tools (crank lock tool?)
Postby Mazda Mender » Tue Jan 19, 2016 7:44 am
Remind me ? SNC or LNC?
sandmonster
Postby sandmonster » Tue Jan 19, 2016 1:15 pm
its the long nose (later?) 8 slot one
Postby Mazda Mender » Wed Jan 20, 2016 8:43 am
So you can re-use the crank bolt, two 1" open spanners and a locking tool, and if needed torque wrench's.
sandmonster
Postby sandmonster » Mon Feb 08, 2016 2:31 pm
Sketching out the removal sequence while on dinner at work because its raining too much to go for a walk... :sad-bored: :sad-bored: :sad-bored:
Disconnect battery
Drain coolant
Remove under tray (if fitted)
Remove air duct
Disconnect hoses from thermostat housing
Remove rad for more room?
Remove aux belts
Remove water pump pulley (3 bolts)
Remove crankshaft damper/pulley (4 bolts)
Remove cyl head cover…
-Remove PVC hose
-Remove breather hose
-Remove ign coils (3 bolts) & HT leads
-Remove cyl head cover bolts (observe sequence)
Remove timing belt upper cover (4 bolts)
Remove timing belt middle cover (1 bolt)
Remove timing belt lower cover (3 bolts)
Align timing marks TDC on #1 cyl – lock camshafts - lock crankshaft sprocket
Undo crank sprocket bolt (Haynes says to release clamps & lower anti-roll bar to improve access).
Loosen tensioner bolt, lever tensioner outward, retighten bolt (protect thermostat housing before).
Remove belt
Remove water pump…
-Undo coolant inlet bolts (2off)
-Undo pump mounting bolts (4 off)
Remove thermostat housing (2 bolts)
Postby Mazda Mender » Tue Feb 09, 2016 7:49 am
Mazda Mender wrote:
sandmonster wrote:Sketching out the removal sequence while on dinner at work because its raining too much to go for a walk... :sad-bored: :sad-bored: :sad-bored:
Disconnect battery..............just earth
Drain coolant....refresh with new
Remove under tray (if fitted)................Rubbish...no need
Remove air duct....and air box
Remove rad for more room?...............Rubbish....no need
Remove aux belts....and replace with new
Remove water pump pulley (3 bolts)..........Crack these bolts before you remove the AUX belts as T*t will keep it under tension to be undone, reverse when building back up.
Remove crankshaft damper/pulley (4 bolts).......same as above
-Remove PVC hose
............Remove air box and all trunking, unbolt PS pump and tie out of the way, clean the CAS body and bracket and mark it to replace the O'ring,,,,
Remove timing belt lower cover (3 bolts)...........Remove this once the crank pulley is out of the way
Undo crank sprocket bolt (Haynes says to release clamps & lower anti-roll bar to improve access).............rubbish
Remove belt
Remove water pump…
Remove thermostat housing (2 bolts)........why?
Check Cam seals and crank seals, they to will need replacing.
Zak
Postby Zak » Wed Feb 10, 2016 11:03 pm
Just about to do this too! Does the thermostat not need to come off then? Might as well not buy the housing O ring if not.
Yolo
Postby Yolo » Wed Feb 10, 2016 11:17 pm
Zak not sure about this and MM has been having trouble with his PC so bear with us and someone will answer soon. :handgestures-thumbup:
