Rain rail stud
Barefoot Ian
Rain rail stud
Postby Barefoot Ian » Mon Dec 12, 2016 8:13 pm
The thread is nackered on one stud that holds the rain rail to the bodywork, so I'm unable to tighten the retaining rail. I now have a small leak in this area! Any suggestions to over come this problem?
Sent from my SM-G925F using Tapatalk
Re: Rain rail stud
Postby Mazda Mender » Tue Dec 13, 2016 7:52 am
Try and get the thread back by re-cutting it with a stronger s/steel nut or tap a die set would be my first call, before it needs to go deeper, but one missing stud should not make it leak, i would check everything first.
Barefoot Ian
Re: Rain rail stud
Postby Barefoot Ian » Tue Dec 13, 2016 8:16 am
Thanks, that's good to know that one bad stud should not make it leak. The beltline rubber is as hard as bullets, so possibly making a bad seal. I will post updates.
