Jolting power steering
MarkEt
Postby MarkEt » Sun Jun 25, 2017 9:41 am
It's been a few days now : right after ignition, when leaving my parking space, I noticed the power steering would jolt. Steering is harder than usual, then it kicks in, and again. I'm talking short jolts, like 2-3 times a second maybe.
It mainly happens when the wheels are almost completely turned, and the car is stopped. And mostly to the left.
I have had one belt slipping when cold, for a while now. Never had the chance to check which one, since it subsides after a few seconds. But since I retrofitted an OEM second hand AC, I think this can be the one. However, there's no suspicious noise when the jolts happen.
Anyway, I plan to replace the belt, check the tension (increase the tension, as I have no tool to check the deflection), drain a bit of fluid as it is overfilled (must have been for a while since I never poured anything into it), eventually replace the whole fluid if it's not clean.
I went drifting couple of weeks ago, on a special track (low grip). At one point I noticed the front drivetrain made a few noises but this light very well have been the wheels slipping/jumping.
Re: Jolting power steering
Postby Mazda Mender » Mon Jun 26, 2017 12:35 pm
Sounds like air in the system.
MarkEt
Postby MarkEt » Mon Jun 26, 2017 8:01 pm
Feels like a slipping belt to me, since it disappears after a while. Mostly.
It only behaves when there's an important effort to provide (car not moving). Plus turning the AC off seems to alleviate the problem.
Postby Mazda Mender » Tue Jun 27, 2017 8:01 pm
Have you tried putting more tension on the belt?
MarkEt
Postby MarkEt » Wed Jun 28, 2017 5:47 pm
Just did. And found out the screw was partially broken (when it broke off completely). Replaced, tensioned again, problem gone.
