Siezed Cranck shaft pulley bolt on Mk2.5
Chris.P.P.Bacon
Postby Chris.P.P.Bacon » Thu Apr 11, 2019 5:53 am
Hi All,
The retaining bolt on the timing belt pulley wheel of my Mk2.5 has seized solid.
No amount of swearing, WD40, Plus gas, Impact wrench will shift it.
Has anyone got any suggestions?
I'd rather not wait until I get stranded at the roadside when it breaks but if that's the only option then so be it.
CPB
Re: Siezed Cranck shaft pulley bolt on Mk2.5
Postby Mazda Mender » Thu Apr 11, 2019 7:33 am
One of the 10mm bolts? or the 21mm crank bolt?
Chris.P.P.Bacon
Postby Chris.P.P.Bacon » Thu Apr 11, 2019 11:20 am
21mm Big bu$$er
Postby Mazda Mender » Thu Apr 11, 2019 11:57 am
What are you useing to lock up with?
Chris.P.P.Bacon
Postby Chris.P.P.Bacon » Thu Apr 11, 2019 1:21 pm
Wasn't me doing it so no sure.
Is it worth buying a locking tool?
Postby Mazda Mender » Thu Apr 11, 2019 7:28 pm
100%>>where are you and who is making a mess at trying to do this very important job to do and get right.
Chris.P.P.Bacon
Re: Siezed Crank shaft pulley bolt on Mk2.5
Postby Chris.P.P.Bacon » Fri Apr 12, 2019 6:11 am
I'm in North Hampshire.
I don't want to mention names as I have every faith that they did all they could.
CPB
Postby Mazda Mender » Fri Apr 12, 2019 7:05 am
I get that, but keep them away from the roadster as they clearly don't know what they are doing bud, its an expensive "got it wrong" fudged it ,to be put right from someone helping and "i'll have a go" rather than "i can do that" if you know what i mean.
I was going to use the one we did at the NEC live for pics and a guide , but busy was an understatement ,so i am doing the daughters this weekend to take photos off and build a guide to be used and followed, which will be a in depth how to in sections to understand for everyone, which will take a full weekend taking pics as i go rather than 3-4 hrs, then i'll work on the guide which with any luck will go live the following weekend.
I may of asked?
Is she a MK 2.5 1.8 VVT or 1.6?
Chris.P.P.Bacon
Postby Chris.P.P.Bacon » Fri Apr 12, 2019 9:15 am
It's a 1.8 VVT.
Thanks.
You're help is much appreciated.
Postby Mazda Mender » Fri Apr 12, 2019 12:29 pm
As the water pump been leaking?
Chris.P.P.Bacon
Postby Chris.P.P.Bacon » Fri Apr 12, 2019 3:15 pm
Don't think so but the car is quite new to me so ...
