Members and searchers please be aware that some of our 'how to' guides do not currently show the intended help photos. This is because photobucket wants to charge a monthly amount for us to view our own pics. The photos are currently being replaced. If you need one of our guides and it is missing pics please let one of the Admin team know and we will make that one a priority for you.
Oil dip stick handle upgrade Mk 1/2/2.5 from Jass performance
Postby Mazda Mender » Fri Dec 01, 2017 8:55 am
On all models from 1989 to 2005 the oil dip stick handle breaks,if it has not yet ...it will simply because of age and heat, and just become brittle, if you get a new one, it will just do the same further down the line..
Jass performance do a very nice alloy upgrade to this issue which fixes to the old broken stub and is fixed solid by way of a allen key grub bolt, and with it being made of alloy, it is light, there are others on the market which are glued into place on the broken stub, but are metal covered in a chrome coat which are heavy and vibrate...a lot.
So this is what we should have that Mazda gave us to check our oil with, ( which gets used a lot on the MK 2 1.8)...
But in reality most of us have a yellow stub from the handle hoop broken away...
So a very nice fix by Jass perfomance...
Remove your dip stick, clean it, Turn the allen key grub nut out on the Jass handle and push the broken stub into the end...
And then just tighten the allen key grub nut back down onto the broken stub to hold it in place, now there is no need to go mad it is not holding an engine in place ...
And done....
And back on the roadster....
Very easy upgrade to a annoying problem, which is not expensive, simple and quick to fit and solved for good...
Can be bought here at Autolinkmx5.... http://www.autolinkmx5.com/dip-stick-ha ... 7222-p.asp
Hope this helps, as always any questions please feel free to ask...
Mk 1 Eunos 93 black V.S II 1.8 fettling,
Mk 1 Eunos 96 1.8 blue B2...being fettled
Mk1 Eunos 93 1.6 black S special **gone**
e.u.n.o.s
Re: Oil dip stick handle upgrade Mk 1/2/2.5 from Jass performance
Postby e.u.n.o.s » Thu Jan 04, 2018 11:37 am
I think I might be getting one of these!
1997 MK1 MX5 Eunos Type II
Darlington UK
Return to “MK1”
