Stripping Black from V Spec Dash
Maccaloon
Postby Maccaloon » Tue Jun 16, 2015 9:47 pm
I spoke to Mm on MX5 Owners about stripping the black from the upper dash of a V Spec. Apparently the dash is tan beneath the black paint (which is bubbled, scratched, and tacky) and was curious as to which chemicals/method to use to get the desired result?
Any help/advice/suggestions are much appreciated!
1992 Eunos V-Spec Roadster
DavesBRG5
Re: Stripping Black from V Spec Dash
Postby DavesBRG5 » Tue Jun 16, 2015 10:38 pm
New some one who did it but can`t find his post......i`ll keep looking but meanwhile......
http://www.mx5nutz.com/forum/index.php?showtopic=108490
DAVE
Postby Mazda Mender » Tue Jun 16, 2015 11:04 pm
Meths 100% everytime and a shed loads of rags done this loads of times , check ou Paulas build thread Rupert the Mk 1.
It is easy enough to do, like anything it is all down to the prep work before hand.
Maccaloon
Postby Maccaloon » Wed Jun 17, 2015 12:03 am
Thanks. When you say prep, what preparations should I make? I'm not sure I will be repainting the dash, I may leave it all tan.
Postby Mazda Mender » Wed Jun 17, 2015 10:22 am
Just remove the dial cowl then ,get some meths and cut up all those old clothes of your wife's for rags ;0) and away you go :obscene-drinkingcheers:
Maccaloon
Postby Maccaloon » Wed Jun 17, 2015 7:01 pm
Cheers, Mm!
chris32
Postby chris32 » Mon Jun 22, 2015 8:24 pm
Hey, that explains a mess I started on my V-special. I tried to clean the black with meths and it went seriously sticky. :oops:
Fortunately only in a small test area. Now I know why and also what might be underneath.
Return to “MK1”
