Remove AC compressor Mk1 Eunos
Does anyone know what is the correct belt to drive the Power Steering pump if the air conditioning compressor is removed from a 1990 Mk1 Eunos 1600? Are there any other bits I need?
Re: Remove AC compressor Mk1 Eunos
Give Andrew a ring at Autolink. He will have the correct belt. You will also need an air con delete pipe for behind the glovebox.
DAVE
http://www.autolinkmx5.com/belt-mazda-m ... 5-12-p.asp
And As Dave as said you will need the UK spec air duct tube from behind the glove box if you have removed the unit.
Thanks Dave and MM. I have got the right belt arriving today and the link piece from a scrapped UK spec Eunos. I removed the compressor last night and found the cause of a nasty rumbling noise which had been bothering me for a week or two. There were only two bolts out of the four that are supposed to hold the cast compressor mounting bracket to the side of the engine and they were loose causing it to bang against the side of the engine. Relief, it sounded like main bearings! I never use AC anyway and it's another 15kg or so off the weight.
Cheers.
Cheers.
