upgrading oil pressure gauge
Shadgrind
Re: upgrading oil pressure gauge
Postby Shadgrind » Fri Oct 16, 2015 4:40 pm
Mazda Mender wrote:Made it a sticky, spot on buddy, just check it over, are the pics all in the correct order?
Where is the sticky, looking at the how to I did, the pics are in the right order but they are duplicated at the end of the post, will see if I can sort them out, tried before but didn't manage it.
Mk2 Twilight Blue. 1.8
Low fuel Autolink light.
Style bar.
Postby flea » Fri Oct 16, 2015 5:50 pm
In the maintenance section under 2-2.5 :handgestures-thumbup:
Here's the link viewtopic.php?f=38&t=5417
Shadgrind
Postby Shadgrind » Fri Oct 16, 2015 6:12 pm
flea wrote:In the maintenance section under 2-2.5 :handgestures-thumbup:
Sorted out the 'extra' attachment pics. It's fine now. Not sure how it happened anyway but fixed.
Style bar.
Postby flea » Fri Oct 16, 2015 6:19 pm
I've had that a couple of times too. Can't remember myself either
Shadgrind
Postby Shadgrind » Fri Oct 23, 2015 4:49 pm
Only one thing, it looks great in the day but the needle must be different on the mk1 as it doesn't glow like the mk2 one. The mk2 needles are clear with white paint on the back ar the mk1s solid white. Can't use the mk2 needle as the spindle size is different. Could modify it I suppose?
Style bar.
Shadgrind
Postby Shadgrind » Tue Nov 10, 2015 2:23 pm
Right, some of you may know that I now have mk2.5 dials, problem is that even after swapping over the circuit board on the back, the OPG now moves as soon as you put ignition on and does not alter as reeves rise, helllllpppp!
Style bar.
Return to “MK1”
