Auto gearbox oil
Don't forget about these models and versions.....
dmt
Auto gearbox oil
Postby dmt » Wed Apr 23, 2014 4:54 pm
Hi, I am finding it difficult to check the oil level on my Mk1 1.6 auto as when the dip stick is withdrawn after following the check procedure there is not a defined line where the level is. Is this normal or does this indicate the oil needs replacing, the oil does not look too dirty. Dave.
Re: Auto gearbox oil
Postby Mazda Mender » Wed Apr 23, 2014 8:35 pm
Is it inbetween the low and high leave marks.
dmt
Postby dmt » Wed Apr 23, 2014 9:22 pm
It looks like it is picking up oil from the tube which is giving a false reading and is different on both sides of the dipstick.
Postby Mazda Mender » Wed Apr 23, 2014 10:25 pm
Let her sit over night, engage/go through all the gears and then dip it.
dmt
Postby dmt » Thu Apr 24, 2014 6:46 pm
Sucked some oil out with oil extraction pump and it is a dark red colour so think I will suck the rest out and fill with new oil, did i read once you recommend not to disturb the filter unless absolutely necessary? Dave.
Postby Mazda Mender » Thu Apr 24, 2014 9:43 pm
If the oil is not a brown colour and does not smell ,then leave it be is the rule of thumb with an auto.
Return to “Auto's ....all marks 1989 to date”
