Wiring for a 4 pin led toggle switch
Tell us what you have done or want to do, or any problems you have hit that we can help you with
GlennyGills
Postby GlennyGills » Tue Jul 23, 2013 9:50 pm
Hi, just about installed the wiring for my new glass window. (New hood courtesy of Jack Smith Trimmer Swansea). I bought a 4 pin red led rocker switch. I got the power to the window, but no led.
The four pins are labelled
Looking at the switch from the rear with the led uppermost.
Earth +
(none) light (?)
Any help?
p's Mm your diagram helped me with the wiring using a relay. Thanks
Re: Wiring for a 4 pin led toggle switch
Postby Mazda Mender » Thu Jul 25, 2013 3:31 pm
:text-worthless:
Lets have a look
binarypunk
Postby binarypunk » Thu Jul 25, 2013 4:49 pm
If there are pins marked + and - then those will be for the LED, the other two will be the switch poles (which might be connected to anything, so +/- doesn't apply)
GlennyGills
Postby GlennyGills » Thu Jul 25, 2013 4:58 pm
Turns out that if you number the pins 1,2,3, 4 and pins 1&2 and pins 3&4 are switched.ie Dual pole,single throw.Then to get the led to light on switching, you have to have +ve on pin 2 and -ve on pin 4. Putting +ve on pin1 and -ve on pin 3 lights the led lights when not switched.
Found this out by taking a switch to pieces.
Thanks...
Return to “Your mods”
