Push Push Switch connector for heated rear screen?
Yak
Postby Yak » Sun Oct 06, 2019 5:25 pm
NA Eunos 1995 with a later roof fitted with heated rear window. The existing HRW wiring uses an aftermarket rocker switch and a separate run of wiring with a relay and it's a bit of a dog's dinner tbh (not installed by me). I'd like to try and use the existing wiring so that I have a light on the dash and a timer etc. I've pulled the existing switches and wires and I now need to confirm that the white plug in the attached pic is for the push / push type switch (NA7566460)
Also, what is the black connector block in the pic supposed to be for?
Thanks in advance
Re: Push Push Switch connector for heated rear screen?
Postby Mazda Mender » Sun Oct 06, 2019 6:41 pm
Yak wrote:Hi,
Thanks in advance
It is all plug and play on your 95 version,,,,picture is blank?
Yak
Postby Yak » Sun Oct 06, 2019 8:37 pm
I'll try the pic again
Postby Mazda Mender » Sun Oct 06, 2019 8:50 pm
Yak
Postby Yak » Sun Oct 06, 2019 9:07 pm
Ah, so the white one is for the HRW and the black for electric door mirrors (which I don't have). Just need to get the single HRW push type switch from Autolink, put the wiring back to normal and sort a pigtail for the HRW then. Cheers :handgestures-thumbup:
Postby Mazda Mender » Sun Oct 06, 2019 9:31 pm
If you get stuck just shout buddy.use the discount code off here for Autolinkmx5.
Yak
Postby Yak » Tue Apr 14, 2020 5:40 pm
Finally got it done, ripped out the additional wring and relay and fabricated some leads to use the rocker switch with the original plug. Made a pigtail using the instructions on here and now it works. A lot tidier and I even have the dash light as well.
