Rear Suspension - Meister R and Bushes Install
bluelightning
Postby bluelightning » Wed Apr 29, 2020 1:33 pm
Good Afternoon. So today I have made a start on the suspension install. I have jacked the rear of the car up and safely supported it on axle stands. I thought I would try and loosen every nut at bolt before getting too far. The first problem I have encountered is this one. I can not identify what it is supposed to be. I think it is a Nut with a split pin behind it, but it seems to just be a big pile of molten rust. I have sprayed WD 40 on it over night and rubbed it with a wire brush to try and identify. So my question is can someone please tell me what size nut (i.e what size socket I will need), confirm whter it is a split pin and give me some advice as to how I can remove it please?
My next step was to heat it with a blow torch and let it cool down but I'm not sure if that is a good idea if it is indeed a split pin behind the nut?
DSC_1405 Insta.jpg (478.79 KiB) Viewed 283 times
Many thanks. Richard
Re: Rear Suspension - Meister R and Bushes Install
Postby Mazda Mender » Wed Apr 29, 2020 3:15 pm
So I am going centre of the pic...17mm nut and should be a bolt head then on the other side, the one that holds the damper to the bottom bone is 17mm with a captive nut in like a cage affair, the other that is sprayed also with a waste of time WD40 is the drop link with a 14 mm nut and bolt, I would invest in some good penetrating oil and leave the old school WD40 for the door hinges in the house.
bluelightning
Postby bluelightning » Wed Apr 29, 2020 6:14 pm
Thank you for the swift response. I couldn't get the 17mm socket on to begin with, but with the confidence that it was the correct size I cleaned it up with a screwdriver and then the 17mm went on. So I have the coilover out now. However, the 14mm drop link nut has just mashed itself. I used a six point socket but obviously I've been too ham-fisted with it and whilst in the process of applying heat the drop link has come away, see the photo below. Will I have to replace the whole drop link once I have the nut off of the ball end, or can this be repaired somehow? Thanks for the help so far, I think this forum is going to be a godsend for a newbie like me.
Thanks again.
Richard
DSC_1417 Drop Link.jpg (413.13 KiB) Viewed 271 times
Postby Mazda Mender » Wed Apr 29, 2020 9:21 pm
There is never any point wasting your time in trying to save or reuse old NB drop links unless new or have been protected...grinder and bin...fit new and get some protection grease on them ...the blue print links are better than the OE items and cheaper.
bluelightning
Postby bluelightning » Thu Apr 30, 2020 7:47 am
Thank you, I will do that then.
I guess this mornings first task is to find a friendly car parts shop in or near to St Helens so that I can get these Blue Print drops and some decent penetrating oil. Do you have any particular recommendations for the penetrating oil?
Postby Mazda Mender » Thu Apr 30, 2020 12:05 pm
Wurth 2040 or plus gas, and try euro car parts for the links, there is an outlet in St Helens..... https://www.google.com/search?q=euro+ca ... e&ie=UTF-8 , you're not that far from me really...Wigan.
John&Luke
Postby John&Luke » Thu Apr 30, 2020 1:13 pm
bluelightning wrote:Thank you, I will do that then.
Hi, if you get a problem releasing the bottom shock bolt see my thread for one solution.
viewtopic.php?f=35&t=6699&start=75
Good luck.
J
bluelightning
Postby bluelightning » Fri May 22, 2020 2:31 pm
Hi, so a little update on progress. I had a nightmare getting the bottom bolt out of the hub carrier, eventually managed to get it out but I had to cut the nut off so had to order a replacement bolt from MX5 parts. I think I have got the last one because they only had one in stock so I hope that the other side goes better. I also had a nightmare getting the old bushes out, they were so degraded that the tube that they sit in had rusted so I had to use a blow torch to melt them out. I don't fancy doing that with the rest of them. Do you think that a Garage Press would have been able to remove them or do you think burning them out was the only option? If a garage press would do it then I will take them to a garage. Some pictures of the rust before and after I cleaned it up.
Before Cleaning up the rust
After cleaning up the rust
Burning out the bushes
Postby Mazda Mender » Fri May 22, 2020 3:19 pm
bluelightning wrote: I had to cut the nut off so had to order a replacement bolt from MX5 parts. I think I have got the last one because they only had one in stock so I hope that the other side goes better.
You do realize that you can also use Autolinkmx5 for new or s/hand parts to and we have a members discount code for them.
bluelightning
Postby bluelightning » Sat May 23, 2020 9:24 am
I did not know that. Thank you I will check them out today. Every day is a school day... :text-thankyouyellow:
bluelightning
Postby bluelightning » Sun May 24, 2020 2:06 pm
So making some progress now, one corner is done!
Only problem is I can not get the brake line off to put my new braided hoses on. On this side the flexible cable goes to a junction box that has two hard lines going into it, but I can not undo the hard brake lines. I have tired penetrating fluid, Ive tried blow torch to heat it up, and I am using a proper flare nut spanner but they will not crack. If anyone can offer any assistance as to the next step to remove the junction box then I would be grateful or can point me in the direction of a thread where someone else has had a similar problem then I would be grateful.
DSC_1557 small.jpg (319.54 KiB) Viewed 64 times
Postby blackyb » Sun May 24, 2020 5:37 pm
We sometimes have to resort to a good set of mole grips locked on as tight as you can then wiggle vigorously back and forth. Just make sure the block is solid.
I am always mindful that brake fluid is highly imflammable so I avoid using heat on brake unions.
bluelightning
Postby bluelightning » Sun May 24, 2020 5:52 pm
blackyb wrote:We sometimes have to resort to a good set of mole grips locked on as tight as you can then wiggle vigorously back and forth. Just make sure the block is solid.
Thank you for the advice I will give mole grips a try tomorrow. I am mindful that I need to reuse the connectors on the copper pipe, if they get damaged getting them off, is there a way to replace them? Or am I in big trouble if if I ruin that threaded connector?
Thanks
Postby Mazda Mender » Sun May 24, 2020 11:19 pm
Yes please be careful with applying direct heat....surface rust is the issue ,scrape or sand the brake line at the union bag smooth....then soak...leave it locked up to the body bracket with the locking slider clip ..lightly grip the pipe with the mole grips , not to hard to crush..and as bry says ...spray it crack it tighten it..spray it...crack it and tighten it...and so on....there is no medals for rushing here.,
If it snaps you can join and re add fresh pipe and unions....but a word of warning." Do not let air in a abs system...
bluelightning
Postby bluelightning » Wed May 27, 2020 8:58 am
If it can go wrong, it will go wrong for me... I think that will be my new saying, still as you learn from your mistakes I should have my own TV show to rival Car SOS soon because I will have learnt so much by the time this is finished.
So I put the blow torch away as I didn't want to blow myself up and set about gently teasing out the brake unions. I started on the 10mm Union running towards the front of the car but it was not budging, so I soaked it in penetrating fluid and started on the 11mm union on the top. I'm not sure why this is a bigger union but I measured it with a caliper and its definitely 11mm. The issue seemed to be that the pipe bent to run across the car immediately out of the top of the union. So the moment that the union turned an 8th of turn and cracked the brake line just twisted with it. I soaked it in fluid and turned it back and forth but to no avail. Then brake fluid started leaking out of it.
Then to compound my misery both of the bolts connecting the junction box to the suspension arm sheared off as well. I used mole grips to hold it in place whilst I attempted to undo the 10mm union again but it was not shifting. I went back to the 11mm and it just twisted up. So I took some photos, walked away and set about thinking about how to fix it.
I have no choice but to drain the system and replace the hard brake lines. I guess that means I will need to get it recovered to a garage to refill the brake fluid from fresh.
Still at least now I get to learn how to install new Brake lines.
Is there a resource somewhere that I can get the correct specifications for the brake lines and unions? I have a mixture of steel / Nickel pipe and copper and different union sizes which also does not seem right?
I have seen complete kits for £80 but some are copper with AF fixings some are Nickel. I was hoping that I could get a flaring tool from Ebay for £30 add a connector to the brake line running from the font of the car and then replace the entire pipe running across the back of the car.
Some pictures, because everyone likes pictures even if they are painful for me to look at haha...
Not a great angle for the picture but there is no straight pipe for the union to screw back up.
Many thanks,
The result is a twisted brake line. Replacement now required.
Return to ‚ÄúProblems‚ÄĚ
Users browsing this forum: No registered users and 7 guests
