********Wishing everyone a far better 2021 after our blur of a year in 2020 as we go into lockdown 3 and the new begining of the end of our leaning on the EU to find our own road again, I am sure it will all sort itself out again in the end as I am sure it will not be easy, as we also battle with China virus, please stay safe and strong as all our mental health tries to make sense of it all, we are still here on line for those that need our help on the spanner side to keep sane to erras all the madness around us, we are on you tube, FB and here if needed, by posting ,messages of email etc*********
Mk1 headlights
Mk1 headlights
Postby John&Luke » Sat Jan 09, 2021 5:05 pm
Hi help please
Mk1 uk spec
Struggling with a problem on my rebuild. Background- As you may know complete strip down and rebuild so virtually every electrical connector has been unplugged and re plugged.
Problem-
With all lights off turn ignition switch to position 2 (run) and headlights raise!!! No lights they just come up on there own.
Turn ignition to off headlights go back down.
Have replaced relay, checked combination switch, check headlight retract switch. All seem ok
Headlight retract switch will raise and lower headlights when ignition is off but does not lower or raise when ignition is in run position.
I’m guessing the lift relay is getting a live feed from the ignition circuit some where but can’t figure where??
An thoughts please.
Re: Mk1 headlights
Postby Mazda Mender » Sat Jan 09, 2021 9:46 pm
Have you checked the stalk..
Re: Mk1 headlights
Postby John&Luke » Sat Jan 09, 2021 11:22 pm
Mazda Mender wrote:Have you checked the stalk..
Yep, even completely disconnected the lights still raise up when I go to the run position.
Re: Mk1 headlights
Postby Mazda Mender » Sat Jan 09, 2021 11:38 pm
Its a UK spec version if i remember, does it have the Toast rack under the bonnet on the passenger side inner wing.
Re: Mk1 headlights
Postby John&Luke » Sun Jan 10, 2021 12:15 am
MM yes the dip dim module. I’ve tried unplug it and checking resistance seems ok. I’ve checked the relay and get th3 correct readings (according to my manual). If I remove the relay them the headlights DO NOT raise.
Re: Mk1 headlights
Postby Mazda Mender » Sun Jan 10, 2021 1:43 pm
You can get issues with that stupid system anything aftermarket been added.
Re: Mk1 headlights
Postby John&Luke » Tue Jan 12, 2021 6:20 pm
I’ve ruled out the light/indicator stalk as even with this removed it still happens. I’ve added gauges (all now disconnected) and upgraded to electric windows (switch now removed) next job tho disconnect the motors, its a trial by error approach.
I think it must be a rouge feed from the ignition circuit as this seems to be the trigger, ignition on = lights up. Ignition off = light down.
Any further advice welcome.
Re: Mk1 headlights
Postby John&Luke » Sat Jan 23, 2021 6:54 pm
Update on headlight problem.
To recap, turn ignition to run, headlights raise and side light within headlights is on. Turn ignition to off headlights retract.
To chase the problem I have checked all the swiich gear and relays, all ok I believe. The problem seems to be that the headlight sidelight is getting a feed through the ignition circuit somehow. In turn the motor is getting a signal to raise.
Today I removed the whole dash again!!! In order to disconnect and reconnect everything one by one to see if I could isolate the feed.
No real joy, so started removing fuses from the interior fuse box one by one. Removing the top 2nd from left hand 10amp fuse seemed to do the trick. Car starts and light ps operate fine with this fuse removed. Unfortunately, my fuse box does not have a cover so I’m a little lost to what this fuse feeds???
In my manual I think it says Tail??? However tail lights and brake light work fine?
See pic’s on the fuse in question. WHAT IS THIS FUSE FOR PLEASE. It’s the one where my screwdriver is pointing?
Re: Mk1 headlights
Postby Mazda Mender » Sat Jan 23, 2021 8:02 pm
The one with the fuse missing is the 10 amp METER fuse which is interior lights, you have something crossed inside or trapped.
Re: Mk1 headlights
Postby John&Luke » Sat Jan 23, 2021 8:21 pm
MM thanks, interesting as I’ve had the doors open (obviously) whilst working on it. So interior light circuit would be hot. Will check further tomorrow.
Thank you :handgestures-thumbup:
Re: Mk1 headlights
Postby Mazda Mender » Sun Jan 24, 2021 12:45 am
this should be of use.....
Users browsing this forum: No registered users and 18 guests
