opening the boot without the lock barrel
madmanstiff
Postby madmanstiff » Sat May 17, 2014 8:01 pm
Hi guys I've been redirected here by someone on the piston heads forum. I'm hoping you can help as I'm kinda screwed at the moment. Earlier I shut the keys in the boot of my mark 1 mx5 luckily the roadside recovery bloke helped me get the keys out. Unfortunately we only manage to get them out by inflating pads under the edge of the boot and fishing them out with some wire. Before we managed this however he had tried to fish the cable that joins the latch to the lock barrel. I won't put up the details as to how we done this but it resulted in unclipped it from the latch. So I now have my keys but no way of opening my boot can anyone please help.
I understand this is a bit of a dodgy question and unfortunately I can only hope you will believe me when I say this information is purely for use on my own car.
Failing this im going to have to take a cutting disc to my car which I would prefer to avoid.
Re: opening the boot without the lock barrel
Postby Mazda Mender » Sat May 17, 2014 8:28 pm
Can you send me a E-mail please and lets see what we can do, Mk 1 or 2 import or UK spec.
madmanstiff
Postby madmanstiff » Sat May 17, 2014 11:10 pm
Hi Wayne sorry have to post my email on here as I'm unsure how to send messages it's madmanstiff at gmail.com cheers
madmanstiff
Postby madmanstiff » Sat May 17, 2014 11:11 pm
Plus it's the mark 1 UK spec 1.6
Postby Mazda Mender » Sun May 18, 2014 11:37 am
madmanstiff
Postby madmanstiff » Sun May 18, 2014 8:07 pm
Fantastic help Wayne all done. There was a slightly perverse pleasure in ripping out the cluster.
For anybody else that is stuck in the same position here is a quick write up of wow to go through the light cluster to open the boot.
You will need hammers chisels and a 10 mm deep reach socket.
You will need.
In all honesty the big hammer and crowbar will be sufficient but very clumsy. I would advise using a small chisel to remove the lense as there is less risk of slipping and putting a beautiful scratch along you car. You will also need a replacement light cluster. Or in my case a friend who has there's tucked in the garage and is willing to let you take the cluster from them. (Note these friends are worth keeping).
PLEASE READ THIS PART CAREFULLY AND CHECK THE NOTES.
now for the fun part.
Break the lense from the light cluster on the drivers side. work from the edges as there are still perfectly fine bulbs that you may wish to keep. Once the lense is of pull out the bulbs and using a bit of brute force and tact break the main body of the cluster.
NOTE!!!!!!!!
when leavering the cluster try to always leaver against the cluster itself or up against the boot or rear quarter using a cloth or old patch of leather to prevent damage to the paintwork. DO NOT leave down or left as the surrounding panel is plastic and is liable to break.
There is a battery very close to the light cluster DO NOT just smash straight through as you may rupture the battery then you will be in a world of trouble. I worked from the left hand side of the cluster to avoid the battery.
Work from the left
Battery is a bit close for comfort.
it is also important to remember the opening is not huge and that if you hammer a chisel through too hard in the wrong place you are going to punch whole through the body of the car. As I found out the hard way. If this does happen don't panic you can always just plug some silicone into the hole although the rubber seal for the light should cover them. The main point is to coat the bare metal to prevent rust.
As you can see above the cluster and below next to the wires I have introduced new air vents. Do not do this.
Once you have got enough space to reach in you will need to trace the top edge of the carpet in the boot and pull out the Christmas tree clips to gain access to the latch. As you can see from the following picture the linkage had been disconnected making it necessary to go to these lengths.
Linkage is hanging down and now have access to the latch.
Run your finger from left to right along the bottom of the latch mechanism and you will undo the latch linkage and hey presto you have access to your boot. I'm afraid I couldn't get a decent picture of where the linkage to undo the mechanism is. But it is very easy to catch if you run your finger along the bottom edge.
Now all you need is to fix the problem which meant you needed this information and to remove the remains of the rear light by undoing the 5 retaining nuts.
NOTE before fitting the new light cluster check that the boot is now working on the key otherwise you will have to break the whole thing apart again.
After fitting the new cluster grab a friend and run through a lights check to make sure it all works.
Last but not least fix some form of secondary release mechanism to avoid future problems.
Badknee
Postby Badknee » Sun May 18, 2014 9:19 pm
:obscene-drinkingcheers: :text-coolphotos: :text-goodpost: :text-thankyouyellow: :bow-yellow:
Paul & Angela.
'93 1.8 in Super Silver
Fully blinged up (thanks M-m)
Lowered into the weeds hung on Gaz Gold Pro's.
Postby Mazda Mender » Sun May 18, 2014 9:37 pm
Glad your all sorted , just remember next time, we are the 5 emergency service :handgestures-thumbup: :wink:
madmanstiff
Postby madmanstiff » Sun May 18, 2014 11:44 pm
Once I have the remote boot release I will do a writ up on how to fit it, if there isn't already a post about it. :)
Postby Mazda Mender » Mon May 19, 2014 7:19 am
madmanstiff wrote:Once I have the remote boot release I will do a writ up on how to fit it, if there isn't already a post about it. :)
Go for it :handgestures-thumbup: :coffee: i get a smaller flush fitting button from maplins to put into the arm rest compartment better well made switch and looks better, on Daryls project Roadster we put a Mk 2 interior in and used a spare dash switch hole with a OE press release switch, so you can use the key, cable or electric popper :handgestures-thumbup:
Note for above how to..... the OE cable to release the boot latch/lock was also unattached and the AA chap who knocked the barrel bar to the latch off, never re connected it, so this was the only way in, in this case with the least amount of damage, just a replacment light unit,, there are other ways in depending on the situation, which we cannot post on here if the keys have been locked in the boot or you are locked out off your roadster, we will help with this info if an owner is stuck by a phone call only,Contact us by e-mail or the PM system, but we will neeed proof that you own the roadster in question before we can help and share the advice.
noisebod
Postby noisebod » Sat Apr 01, 2017 11:11 pm
Sorry guys i,m new here although i have owned my UK spec 1.8 Mk1 for many years.
I too have the problem of locked keys in the boot! argh......
Mine's a 95 model without internal release cable and i never got round to fitting an electronic popper..........
I dont expect anyone to provide details of how to break into boots for everyone to see and have my V5 handy to prove I own one.
Can anyone help?
Postby Mazda Mender » Mon Apr 03, 2017 9:54 pm
Contact me by pm buddy.
noisebod
Postby noisebod » Tue Apr 04, 2017 9:56 pm
Thanks M-m, will do as soon as the forum lets me!
noisebod
Postby noisebod » Tue Apr 04, 2017 9:58 pm
Happy to make a donation if that moves things forward more quickly?
Postby Mazda Mender » Tue Apr 04, 2017 10:59 pm
I cannot tell you on line on an a open forum on how to break into a roadster as i am sure you understand.
2 posts left to be able to contact me by pm buddy.
