Laserline Alarm Control Box Location?
Shadgrind
Postby Shadgrind » Fri Aug 22, 2014 8:18 am
Any ideas, looked up behind glove box and removed cowl on steering column, no sign of it![POUTING FACE]
Mk2 Twilight Blue. 1.8
Low fuel Autolink light.
Style bar.
Doogledog
Re: Laserline Alarm Control Box Location?
Postby Doogledog » Fri Aug 22, 2014 8:46 am
Behind stereo?
Eunos Roadster VR-Ltd comb B - lots of mods
Postby Mazda Mender » Fri Aug 22, 2014 9:25 am
:text-imwithstupid:
Follow the wires :coffee:
Shadgrind
Postby Shadgrind » Sat Aug 23, 2014 2:46 pm
Tried following wires, from siren, they go through bulkhead then are taped to some other wires then I lose track of them, must be behind dash somewhere, going to have to rip it out I guess, how much work is that, any how to's?
Style bar.
Incalcitrant
Postby Incalcitrant » Sat Aug 23, 2014 5:45 pm
Last few MX5s I've seen have the boxes installed around the fusebox.
If you look up where the interior fusebox is, have a look around there, the two I've had have both have them installed with brackets fixed to the fusebox retaining screws.
Costs nothing to have a look!
Postby flea » Sat Aug 23, 2014 5:48 pm
That's where both of mine are up above the fuse board :handgestures-thumbup:
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 6:27 pm
Could be there but it's really hard to access, I have seen the fuse box it must be small!?
Style bar.
Shadgrind
Looking again...
Style bar.
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 7:01 pm
No sign, lying down face up in the footwell, legs over these at back, definitely not there, torch to see all possible locations.
Style bar.
Postby Mazda Mender » Sun Aug 24, 2014 8:58 pm
Behind the HU
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 9:58 pm
Not enough room. HU is tight fit, ducting for heater behind that and behind that not enough room either, looked on both sides of the central tower, nothing!
Style bar.
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 10:01 pm
DUPLICATE!
Style bar.
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 10:02 pm
DUPLICATE!
Style bar.
Shadgrind
Postby Shadgrind » Sun Aug 24, 2014 10:04 pm
Mods delete dupes please[WEARY FACE]post failed and retried using imagur
Style bar.
Postby Mazda Mender » Sun Aug 24, 2014 10:05 pm
Pic worked :text-goodpost: :laughing-rolling:
Where are you, I'll find the bl**dy thing so you will be able to sleep at night again, :coffee: :wink:
