Turret Oil Replaement
Gary Beale
Postby Gary Beale » Sat Nov 15, 2014 7:34 pm
Hi all
I want to change the turret oil (shifter) do I use the same gearbox oil?
1991 Mariner Blue. Rear Spoiler, L.E.D Sidelights, Lexus Rear Lights, Hard Top, Style Bars, Flash to Pass, K&N Air Filter, Magnacor 8mm HT Leads, Strut Brace, SS Exhaust, Decat, LED running lights, Front Splitter, Deep Dish MOMO Steering Wheel.
Re: Turret Oil Replaement
Postby Lazza » Sat Nov 15, 2014 7:46 pm
Use any oil you have spare. Gear oil, engine oil, olive oil... It doesn't mix with the gearbox oil and only has to lubricate the linkage, not meshing gears so there is no requirement for anything special.
nedski
Postby nedski » Sat Nov 15, 2014 8:06 pm
:text-imwithstupid:
Postby Mazda Mender » Sat Nov 15, 2014 8:44 pm
Lazza wrote:Use any oil you have spare. Gear oil, engine oil, olive oil... It doesn't mix with the gearbox oil and only has to lubricate the linkage, not meshing gears so there is no requirement for anything special.
:text-goodpost: :text-imwithstupid: :handgestures-thumbup:
Gary Beale
Postby Gary Beale » Sun Nov 16, 2014 11:03 am
Thanks for the help.
renagade
Postby renagade » Sun Jun 28, 2015 5:03 pm
How do I get to my Turret to oil it. My gear stick is a little stiff. :think:
Postby Mazda Mender » Sun Jun 28, 2015 9:33 pm
Take the centre arm rest out, remove the upper gearshaft boot 4 x 10mm bolts lift it up and you will see the lower gearshaft boot held in place with 3 x 10mm bolts, remove those and lift the gear shaft out, but some oil in and fit everything back up, all this is under the case of your boots being in good condition and can be reused? check the boots first before doing this so you can order them in if needed.
andymaxwell
Postby andymaxwell » Wed Jul 15, 2015 11:33 am
Good information here.
NOTE: If you have a 6-speed gear box you won't have the 'turret' to put the oil into. You'll just be pouring oil into your gearbox and wondering why 85cc of oil won't fill it up. DONT add an extra litre of oil like I did (although Mazda did say it wouldn't cause huge problems).
1998 Mk2 1.8 6-speed Jap RS
See a Picture
Postby flea » Wed Jul 15, 2015 7:09 pm
andymaxwell wrote:Good information here.
:laughing-rolling: sorry but good point :handgestures-thumbup:
Postby Mazda Mender » Thu Jul 16, 2015 6:44 am
NOTE:-....it is not just the six speed.
andymaxwell
Postby andymaxwell » Thu Jul 16, 2015 4:24 pm
Ah, interesting Mr Bond. :bow-yellow: Which other boxes are we talking here? :think:
See a Picture
71notout
Postby 71notout » Thu Dec 17, 2015 10:44 pm
I bought a turkey baster for £1 from Morrisons (other supermarkets are available) which made removal of the old oil and insertion of the new stuff much easier.
I also needed to fit the upper/lower boots and nylon ball on bottom of gearstick - I bought a refurbished kit from mx5parts.
storm
Postby storm » Fri Mar 25, 2016 2:12 am
Mazda Mender wrote:Take the centre arm rest out, remove the upper gearshaft boot 4 x 10mm bolts lift it up and you will see the lower gearshaft boot held in place with 3 x 10mm bolts, remove those and lift the gear shaft out, but some oil in and fit everything back up, all this is under the case of your boots being in good condition and can be reused? check the boots first before doing this so you can order them in if needed.
A rebuild kit and new boots should definitely be considered. Also if we choose to go by the book, we must use 75W90 GL-4 Gear Oil in the turret.
I took this opportunity to fit a short shifter, new boots & a rebuild kit from MOSS Europe.
drumtochty
Postby drumtochty » Fri Mar 25, 2016 12:21 pm
<Also if we choose to go by the book, we must use 75W90 GL-4 Gear Oil in the turret.>
Which book specificaly staets that.
2008 Mk3 Copper Red
storm
Postby storm » Fri Mar 25, 2016 4:47 pm
drumtochty wrote:Which book specificaly staets that.
By that i meant we use leftover transmission oil (turret is technically a transmission component). Yes i know any lubricant could be used as there is almost no friction/wear here but GL4 (75W90) is thick and the viscosity is barely affected by temperature change, which means the gear selection always feels the same.
Users browsing this forum: Bing [Bot] and 5 guests
