Torque wrench for Rocker Cover
chris32
Postby chris32 » Mon Mar 09, 2015 8:42 pm
I need to change the CAS O-ring on my '90 MX5. I read on this forum that the job is easier with the rocker cover off. However I also read that I should torque the bolts on the cover to 43-78 inch-pounds which I think is around 3.5-6.5 Foot pounds which in turn converts to 4.74-8.8 NM.
I do have a torque wrench but it's range only starts at about 20 NM. I bought it years ago to bolt a head down on another car.
Can anyone suggest a reasonably priced torque wrench that will go down to these lighter torques.
Re: Torque wrench for Rocker Cover
Postby blackyb » Mon Mar 09, 2015 9:05 pm
I am hoping so as I could do with one as well???
:-D
Postby Mazda Mender » Mon Mar 09, 2015 9:31 pm
Please please please do not ever use a torque wrench for this , most of the info on settings are to tight on the internet and will snap bolts.
Just Tighten them all up following the 1>14 and just go around again and just nip them up.
rocker cover.jpg (4.85 KiB) Viewed 825 times
Postby Lazza » Tue Mar 10, 2015 10:21 am
Just imagine the bolts are screwing into a block of cheese rather than aluminium - treat it carefully and it'll be fine. It's only an oil cover, nothing mechanical so no need for the bolts to be tight.
Postby Mazda Mender » Tue Mar 10, 2015 10:30 am
:text-imwithstupid:
Postby blackyb » Tue Mar 10, 2015 10:04 pm
Don't want the torque wrench for that particular process but I do for some work on my Two Wheelers!!
:bow-yellow:
chris32
Postby chris32 » Sat Mar 14, 2015 9:52 am
Thanks for the replies.
I read this on the Miata forum.
"I have a 10mm socket on a 1/4" drive screwdriver handle type thing.... the handle is only half an inch diameter or so.... and I just do them up as tight as I easily can with my fingers gripping the handle....
Fletch."
I take the point, Lazza, about thinking of it as screwing the bolt into cheese. So my plan is to use a 1/4" Screwdriver socket and go round the sequence mentioned above a number of times, and not use a lever-style ratchet handle at all. I've also bought some silicon sealer. I guess the gasket is only soft rubber after all.
Does that sound OK to you?
