Mk2 Oil leak and valve seal issues
kevham
Postby kevham » Sun Aug 23, 2015 8:42 pm
Ok - 2 issues I'd like to resolve in my Mk2 RS sprint car over the winter:
1. Oil leak from front of engine - very slight weep on alternator side, evident after car has sat for a few days. cam seals apparently done when cam belt changed back in March. Could this be valve cover gasket or crank seal?
2. Smoke on overrun - most likely valve stem seals? Can these be changed without removing the head? If so, what are the special tools needed and is there a good guide somewhere on how to do it?
Mk2 Roadster RS in white
racingfive.blogspot.com
nedski
Re: Mk2 Oil leak and valve seal issues
Postby nedski » Fri Aug 28, 2015 11:33 pm
oil leak from drivers side could be.
oil filter not sealed correctly
oil pressure switch leaking
crank oil seal rocker gasket.
Give it a good clean off mate and get a torch in there see if you can see it dribbling from anywhere .
Postby Mazda Mender » Sat Aug 29, 2015 12:03 am
:text-imwithstupid:
Plus it is head off for question number 2.
kevham
Postby kevham » Sun Aug 30, 2015 6:57 pm
The leak is from the front - not the side. It only does it after a sprint/Hillclimb when its been revved hard. I'll have to get the covers off to see where but I suspect the valve cover gasket.
As for the valve stem seals, I'm probably better sourcing another engine.....
Postby Mazda Mender » Mon Aug 31, 2015 12:26 am
kevham wrote:As for the valve stem seals, I'm probably better sourcing another engine.....
I know where there is a good R.S/V.S engine. :handgestures-thumbup:
As for the leak at the front...cam seals or crank seal.
Postby Mazda Mender » Mon Aug 31, 2015 12:28 am
kevham
Postby kevham » Sun Dec 27, 2015 2:00 am
Just to close this off, the leak at the front was down to the valve cover gasket. It was an aftermarket one and I replaced it with the much superior Mazda version which cured the leak.
Valve stem seals still puff on overrun but I met a previous owner of the car who told me it had being doing that 5 years ago! :auto-layrubber:
