Nc clunking noise at rear
Bryan29
Postby Bryan29 » Tue Aug 29, 2017 8:49 pm
Clunking noise when going over rough roads chevrons etc?? Any ideas?
drumtochty
Re: Nc clunking noise at rear
Postby drumtochty » Tue Aug 29, 2017 10:07 pm
Get the back end in the air in a safe manner.
On each of the antiroll bar drop link fixing bolt put a breaker bar on each one and give them a good pull and listen and look for movement in the joint. Do the fronts as well.
Change the ones that are loose.
Rear wheels off and check the rear pads are not loose in the rear calipers.
Sometimes the inner plastic items inside the springs can be loose but that may be the fronts. I have not had that problem but others have had that problem.
Postby blackyb » Wed Aug 30, 2017 10:46 pm
As the man says, drop links and anti roll bar bushes, not expensive and an easy to check and fix.
If they are not the fault, check the bottom bush on the shockers and check the springs are all in tact.
:handgestures-thumbup:
Postby Mazda Mender » Thu Aug 31, 2017 11:59 am
Check drop links,sway bar bushes,suspension bushes,broken spring,top mount loose, anything loose in the boot ...jack etc..
