Crankshaft Pulley Mk2.5
scunninghamk
Postby scunninghamk » Tue Feb 13, 2018 2:58 pm
I’ve been suspicious of the Crankshaft pulley for a while as it is pretty rusty and has been for a while.. but I opened the bonnet to find that the alternator pulley belt was on its last legs and so I’m preparing to replace the belts with new. But while I’m down there I wondered about changing the crankshaft pulley as well.
2 questions. Where the heck can I get one? Is it fairly simple, and are there pitfalls that an mechanical idiot like me isn’t seeing???
V6 Power Junkie
Re: RE: Crankshaft Pulley Mk2.5
Postby V6 Power Junkie » Tue Feb 13, 2018 3:40 pm
scunninghamk wrote:I’ve been suspicious of the Crankshaft pulley for a while as it is pretty rusty and has been for a while.. but I opened the bonnet to find that the alternator pulley belt was on its last legs and so I’m preparing to replace the belts with new. But while I’m down there I wondered about changing the crankshaft pulley as well.
Something like this is worth a thought to take some weight off your engine, but I'm sure you'll pick one up plenty of spares for them about, or go and get yours sandblasted and put a bit of paint on it
https://technotoytuning.com/toyota/16v4 ... k-pulley-0
Sent from my LG-H815 using Tapatalk
If the link don't work type lightweight crank wheel
Last edited by V6 Power Junkie on Tue Feb 13, 2018 3:40 pm, edited 4 times in total.
Speedy
Re: Crankshaft Pulley Mk2.5
Postby Speedy » Tue Feb 13, 2018 4:13 pm
Try http://www.autolinkmx5.com/mazda-mx-5-parts-8-c.asp Give Andrew a ring I'm sure he will have all the bits you require.
