Electric Window Regulators
A section to help identify the most common parts that can fail and need replacing, for servicing etc, also the parts that are compatible through the Marks
MrChrome
Postby MrChrome » Fri Dec 21, 2012 2:40 pm
The Electric Window Regulators on MK1, Mk2/Mk2.5 and Mk3 are different.
The are handed and you can check which side they are by the stamped L or R on the end of the regulator... REMEMBER LEFT and RIGHT are taken as if you were sitting in the driver seat...
Here's a MK1:
Now at DoctorMX5...
MrChrome
Re: Electric Window Regulators
Postby MrChrome » Fri Dec 21, 2012 2:41 pm
Here's a MK2/Mk2.5:
NOTE the motor is slightly SHORTER and the mounting points are slighter further apart. So they won't fit a MK1!
Now at DoctorMX5...
MrChrome
Postby MrChrome » Fri Dec 21, 2012 2:43 pm
Here's a MK3:
Now at DoctorMX5...
Return to “Identifying the differences between the most common parts.”
