Re: Differences between the thermostat housings.
A section to help identify the most common parts that can fail and need replacing, for servicing etc, also the parts that are compatible through the Marks
Postby Mazda Mender » Thu Dec 20, 2012 10:49 pm
The differences between the water pump outlet pipes, thermostat housing and tops..........
Left to right....
Mk 2.5 1.8cc-1.6cc, thermostat housing, note the wider pipe on the T piece and the thermostat opening is at the front......
Mk 1 1.8cc/ Mk 2 1.8cc-1.6cc, thermostat housing, note that the thermostat opening is at the front........
Mk 1 1.6cc, Thermostat housing, note that the opening for the thermostat is on the top.......
Common faults:- The body is made of alloy and the T piece steel, so the T piece rusts from the inside out causing a leak, the only cure is to replace the full unit.
Thermostat Housing tops....
Left to right....
Mk 1 1.8cc/Mk 2 1.8cc-1.6cc/Mk 2.5 1.8cc-1.6cc
Mk 1 1.6cc ,Note the port for the sensor - the fan switch
Water pump outlet pipes....
The top one is for the Mk 2.5 1.8cc - 1.6cc, Note the wider curved small pipe.
The bottom one is for the Mk 1 1.6cc - 1.8cc, Mk2 1.6cc - 1.8cc, note the thinner L shaped welded small pipe
Common faults:- The body is made of alloy and the L shape and curve are metal, so they rust from the inside out causing a leak, only cure is to replace the full unit.
Return to “Identifying the differences between the most common parts.”
