Water pumps
A section to help identify the most common parts that can fail and need replacing, for servicing etc, also the parts that are compatible through the Marks
Water pumps
Postby Mazda Mender » Sat Dec 22, 2012 12:02 am
Water pumps.........
All Mk2 and Mk2.5 have the 1.8 Water Pump - the rule is, if it has a multi-rib alternator belt - it has a 1.8 water pump!
1.8cc water pump, note the extra bit on the left with the threaded hole for the alternator bracket
1.600cc (Mk1 only) water pump, note that the extra bit on the left is not needed for the alternator bracket
Return to “Identifying the differences between the most common parts.”
