The Teamdynamics Miata Spec wheels are normally sold and available in USA and quite difficult to source in UK with this specifications. They are based on the Pro Race 1.2 wheels, but additionally lightened as made to use on lightweight MX5s. The bolt pattern, center bore, offset are the correct ones, here the exact specifications:
Wheel size: 15" - the perfect MX5 size, lightweight and works with all standard brake calipers.
Wheel width: 7" - perfect size for tire width 195 and 205, still lightweight.
Center bore: 54.1mm - plug and play, no adapter rings needed, just tailored for MX5.
Hole pattern: 4 x 100mm - as needed.
Made in: England and reliably used in many racing series.
The best at last:
Offset: We have them in the offset of 25mm! That takes the tire 15mm further out compared to the stock setting, saving the weight and price of aftermarket spacers normally used for this.
Weight: 13lbs or 6kg - a brilliant number for race certified wheels with offset number of 25. Keeps the brilliant MX5 suspension working as it should.
Available in both gloss and matte black.
Pictures with bigger size are available here:
https://www.facebook.com/media/set/?set ... 837&type=1
