Brake warning light
- New
Brake warning light
Hi I have been trying to sort this out for a months now and still not getting any were with it. I have a mk1 mx5 and can't get the brake warning light to go out on the dash when I drop the hand brake the light will dim a bit but not go out.
Re: Brake warning light
Which model and version, we need more info from you, give us the full story.
Brake warning light
Whatever the model though, have you checked the fluid level. Could be low on brake fluid? If it isn't then, like M-m says it could be a few different possibilities.
Oh and have you adjusted your handbrake cable before this happened, if so how tight is it, how many clicks up before it locks the rear wheels?
Mk4 Machine Grey 2.0 184BHP, SE-L + Nav and Apple Carplay
Dodgy switch earth?
- New
It's a 1.8 mk1 1996
- New
If I start the car so the charge light goes out so dose the brake warning light goes out to. Then when I operate the handbrake the light works as normal
Are you saying that the light only stays on while the key is switched to the start position but the engine isn't running?
And it goes out and works normally with the handbrake?
- New
If I turn the key to the on position the brake warning light stays on when operating the handbrake if I start the engine so the car is running and the battery light goes out the brake warning light goes out if I drop the handbrake but won't go out if the car isn't running and the battery light is on
Is there a immobiliser fitted?
- New
No immobiliser
It is a bad earth, check for anything aftermarket that as been installed ,which is crossing through that circuit.
- New
I have checked all the wiring from start to finish and there's nothing wrong with it
Only a thought, duff switch?
