Jass performance Mk 1 LED boot light
Come in and have a look at the magic world of our Vlad with his magic hands and great mind, to turn anything into a piece of working art if there is anything you think that is needed in the world of the Mx/roadster, or missing, let him know, has he his another that is not happy unless he is creating something new.
Postby Mazda Mender » Tue Mar 10, 2015 10:48 pm
Good old Vlads boot light mod from Jass performance. I have done a guide for the Mk 2/2.5 so thought it was time to do one for the MK 1's also, so here goes.....
This is a simple mod that will make a lot of difference.
Tools needed...
1/4 drive ratchet
1/4 drive 10mm socket
1/4 drive extension
Wire snips
Heat shrink
Soldering iron/solder
Wire ties
Length of single strand wire.
As the packet arrives....
Lets get it all out.....
So lets start...pop the boot and crack and remove the two 10mm head bolts that hold the boot locking loop to the boot lid, please note the direction of the F and arrow on the plate for reattachment. Put everything to one side as we will be needing it all again later...
Add a bit of copper slip to the threads...
Now get the light plate from the kit and place it under the locking loop plate with F and arrow directed to the LED....
Offer both back up to the boot lid with the F and arrow directed to the boot/front and reattach with only one of the 10mm head bolts and only finger tight For now. Now the positioning of the switch is your choice, we use the left bolt hole simply because of the wire run following the brake light wire with this version being a Eunos Japanese import, this will be different in some versions as some were not built with them across Europe.
Now get the switch from the kit, screw the narl nut to the top to give us full adjustment so we can lock it up to our final position when finished...
Once you have screwed the switch in, tighten the 10 mm head bolt up now but do not lock up the narl nut on the switch as we have not finished final adjustment.
Locate the gray snap connection coming off the LED and the wire off the switch, one side of the snap connection presses in, do so and feed the switch wire into it until it stops and release the snap connection and tuck it out of the way...
Run the wire off the light, following the cable run and lugs from the boot light if fitted...
Now, because of the way I am running, I found the wire was not long enough, and I hate seeing add-ons on these with washing line wires/cables running everywhere, so the choice is down to the owner on your route. I like it out of the way and neat, so I cut the fuse connector off to be reattached later...
So new cable added and soldered together and covered with a heat shrink...
Now to start routing the wire and locking in place with cable ties to be cut down later...
I removed the back panel so i can route with the tow bar wires ...
Once routed and cut to the right length, we need to solder the fuse holder and battery connection back together again, not forgetting to slide the heat shrink on first...
And then it's a case of connecting up to the battery (remove the fuse from the holder before connection) undo the live bolt and nut from the battery clamp with a 1/4" drive ratchet, small extension and a 10mm socket ...
Put the fuse connection on the the bolt side, thread it through and add the nut...
And tighten back up....
Once tight re-add the fuse & cap and secure safely. Now the LED light should light up.....
Now it is time to test that the switch works and to fine tune it if needed. The easiest way to do this is with your phone on record, close the boot, pop it open again and check the Vid to see if it goes off or stays on when the boot is closed. Adjust as needed and re-test until it works correctly with any luck like this one, first go...
https://youtu.be/O3HuhA1XQWU
Nip up the knurled nut on the switch and we are all done...
As always, any questions please just ask.
jass
Re: Jass performance Mk 1 LED boot light
Postby jass » Thu Dec 08, 2016 10:10 pm
Cheers Wayne, amazing how-to as usual!
I am sorry to have put you through the trouble of needing additional soldering (straight forward installation is the goal). The boot light kits are prepared with longer wire for a while now and I am afraid you have received for some reason an older version. Sorry again for the hassle with it!
Postby Mazda Mender » Thu Dec 08, 2016 10:33 pm
Never a hassle Vlad..always happy to help buddy.
Fifty Shades of Red
Postby Fifty Shades of Red » Wed Dec 14, 2016 10:45 pm
This is on the to do list
Sent from my Nexus 6P using Tapatalk
Return to “Jass performance”
